yangin Posted 17November, 2017 Report Share Posted 17November, 2017 Hi all,I am interested in these rims, could someone advise if they will they fit my mk1 c2? Thanks.https://www.design911.co.uk/mobile/#part;id=129904Front wheels 8.0J ET42Rear wheels 10J ET47 Link to comment Share on other sites More sharing options...
Carrera28 Posted 18November, 2017 Report Share Posted 18November, 2017 If you go to this website:http://www.willtheyfit.com/You can enter the dimensions and compare.18 inch standard rear rims on a 996 have an offset of 65 and width of 10 (page 181 of owners manual) which means the wheels you have picked will stick out 18mm more than OEM18 inch standard front rims have an offset of 50 and width of 7.5, with the different offset and wider rim (8 v 7.5 OEM) the fronts will be 3mm closer to the strut and stick out 9mm more on the outside edge than OEM Link to comment Share on other sites More sharing options...
9fan Posted 18November, 2017 Report Share Posted 18November, 2017 Hi yangin,I have a set of those style in offset that will fit - 8x18 ET 50 10x18 ET 47 in VG condition for $!600. As Carrera says rears out 18 mm on standard.Other styles that will fit also.Message if interested. Cheers, Mark. Link to comment Share on other sites More sharing options...
yangin Posted 18November, 2017 Author Report Share Posted 18November, 2017 Im pretty sure they will fit, my bigger concern is if it will look odd particularly the rear Hi yangin,I have a set of those style in offset that will fit - 8x18 ET 50 10x18 ET 47 in VG condition for $!600. As Carrera says rears out 18 mm on standard.Other styles that will fit also.Message if interested. Cheers, Mark.pm sent Link to comment Share on other sites More sharing options...
dan_189 Posted 19November, 2017 Report Share Posted 19November, 2017 They look good, I think cargraphic make a similar set but not at that price point! Link to comment Share on other sites More sharing options...
Mike737 Posted 19November, 2017 Report Share Posted 19November, 2017 9 hours ago, dan_189 said: They look good, I think cargraphic make a similar set but not at that price point! Correct. I'm pretty sure @Simonk is/was running the Cargraphics on his 996 if he hasn't sold it already. Link to comment Share on other sites More sharing options...
Simonk Posted 20November, 2017 Report Share Posted 20November, 2017 Yep, Cargraphic. I'm pretty sure they run the factory width and offsets. 996 boat ramp 2 by RR Films, on Flickr Link to comment Share on other sites More sharing options...
yangin Posted 20November, 2017 Author Report Share Posted 20November, 2017 7 hours ago, Simonk said: Yep, Cargraphic. I'm pretty sure they run the factory width and offsets. 996 boat ramp 2 by RR Films, on Flickr That is the nicest looking 996 c2 ive seen. What is your suspension setup? I did try cargraphics but they are quite dear unfortunately. Little more $$$ and I can get BBS lm's Link to comment Share on other sites More sharing options...
Simonk Posted 29November, 2017 Report Share Posted 29November, 2017 On 11/20/2017 at 6:43 PM, yangin said: That is the nicest looking 996 c2 ive seen. What is your suspension setup? I did try cargraphics but they are quite dear unfortunately. Little more $$$ and I can get BBS lm's Eibach Pro Kit springs on standard shocks. It rides nice. Link to comment Share on other sites More sharing options...
