Merv Posted 8June, 2018 Report Share Posted 8June, 2018 It seems that my Gen 2 987 Boxster has phone connect, iPod connect, back up sensors and all the other useful bits. However, the DVD for the Sat Nav seems to be missing. At least I can't track it down yet. Are these available for the cars and also are upgrades available (at less than the factory cost)? Does anyone have one that they no longer need? Link to comment Share on other sites More sharing options...
Redracn Posted 8June, 2018 Report Share Posted 8June, 2018 The 3.0 uses an internal hard disk for the maps. The std phone is GSM which no longer exists in AUS but the integrated bluetooth using the hands free protocol works ok. Link to comment Share on other sites More sharing options...
Merv Posted 8June, 2018 Author Report Share Posted 8June, 2018 Yes the phone connects easily and well. Strange then that the map does not show as being available on the system. I can see sellers offering DVD for the models up to 2013 Link to comment Share on other sites More sharing options...
Allan C Posted 8June, 2018 Report Share Posted 8June, 2018 Try Euro Car Updates - 30 Maud Street, Maroochydore. https://eurocarupgrades.com.au/porsche I obtained my PCM 2.0 map update from them, look identical to the map update from Porsche but at a fraction of the cost Link to comment Share on other sites More sharing options...
Redracn Posted 8June, 2018 Report Share Posted 8June, 2018 Map updates are available from Porsche. They load them directly onto the hard disk. Latest is about 2 years old and they have been expecting a new telease for a while now. Link to comment Share on other sites More sharing options...
Merv Posted 8June, 2018 Author Report Share Posted 8June, 2018 Thanks again. You are right of course. It does not have a DVD per se but loads onto a HD or flash memory. I wonder what it is not there however. It says navigation is NOT ACTIVE. Link to comment Share on other sites More sharing options...
FZP Posted 23June, 2018 Report Share Posted 23June, 2018 Is this a new car to you and have you had the NAV work before? It may not have the NAV module from factory and as far as I'm aware it's not a retrofit either. It's either do without and use a TOMTOM or buy a second hand unit and take it to Porsche to have it coded to your car Link to comment Share on other sites More sharing options...
Merv Posted 29June, 2018 Author Report Share Posted 29June, 2018 Problem solved. I bought the car from a good friend and he said that the SATNAV had stopped working. It seemed to locate somewhere hear new Caledonia. After some reading and checking I found that the windscreen had been replaced due to stone chip, and so I pulled off the cowling under wipers and around the air filter and they hadn't reconnected the aerial for the GPS! Drove the car for a few kilometres and it re-located to where I actually was. All good. Link to comment Share on other sites More sharing options...
firstone Posted 29June, 2018 Report Share Posted 29June, 2018 Very clever Merv. Link to comment Share on other sites More sharing options...
