TwoHeadsTas Posted 15June, 2018 Report Share Posted 15June, 2018 I need a top up of my coolant, and seeing as there isn't a P dealer anywhere close that I can immediately access, what aftermarket options have you guys used? I've done a bit of research on Rennlist etc, and they mention brands that I don't think would be readily available at my local Repco, Autobarn or Supacheap. Fallback is a visit to the VW or Audi dealer for their G12. Thoughts? Link to comment Share on other sites More sharing options...
Ozvino Posted 16June, 2018 Report Share Posted 16June, 2018 Red coolant? Nulon red should be fine, its G12 Disregard any motor vehicle branding, its BS - monoethylene glycol is the base product and it all comes from a handful of chemical plants, all Porsche is doing is slapping a sticker on it. Look for the type (G12) Link to comment Share on other sites More sharing options...
Stephen Tinker Posted 16June, 2018 Report Share Posted 16June, 2018 Or if you only need a small quantity, top up with distilled (demineralised) water. There is approximately 25 litres of coolant in your 996 / 987 so a few ml of water won't dilute the coolant overall..... Link to comment Share on other sites More sharing options...
Rob Posted 16June, 2018 Report Share Posted 16June, 2018 1 minute ago, Stephen Tinker said: Or if you only need a small quantity, top up with distilled (demineralised) water. There is approximately 25 litres of coolant in your 996 / 987 so a few ml of water won't dilute the coolant overall..... ... and that is about 40% concentrated coolant (ethylene glycol + secret herbs & spices) and 60% water. You can use clean rainwater rather than deionised/demineralised with no problem. Link to comment Share on other sites More sharing options...
tazzieman Posted 16June, 2018 Report Share Posted 16June, 2018 You don't need much branded chemical coolant , even if you live in the frozen north of Tas ☺️ And of course Tassy rainwater is cleaner than distilled water Link to comment Share on other sites More sharing options...
TwoHeadsTas Posted 16June, 2018 Author Report Share Posted 16June, 2018 4 hours ago, Stephen Tinker said: Or if you only need a small quantity, top up with distilled (demineralised) water. There is approximately 25 litres of coolant in your 996 / 987 so a few ml of water won't dilute the coolant overall..... Yep, that's what I ended up doing. Will leave the big purchase for when I replace the header tank shortly..... Link to comment Share on other sites More sharing options...
