woot woot Posted 15May, 2023 Report Share Posted 15May, 2023 3 hours ago, CapnHyaku said: I assure you it isn't, CEIKA have confirmed: "The 996 C4 is different, the coilover can be adjusted like a standard coilover (like the rear for example. I attached a picture. We can't make it like that on the C2 because the diameter is too thin )" Yep, exactly the problem I have. New spacers on now: Ok I stand corrected haha. Wow I did not think they would limit the design that way. Full disclosure one of the designers at Ceika was a member of a car club I used to be a part of, and he was pretty specific with his engineering and measurements. Glad it is sorted though CapnHyaku 1 Quote Link to comment Share on other sites More sharing options...
tomo Posted 15May, 2023 Report Share Posted 15May, 2023 7 hours ago, woot woot said: and he was pretty specific with his engineering and measurements. Glad it is sorted though Apparently not 😉 CapnHyaku, JWM and woot woot 3 Quote Link to comment Share on other sites More sharing options...
CapnHyaku Posted 24May, 2023 Author Report Share Posted 24May, 2023 On 08/05/2023 at 13:53, CapnHyaku said: So here is a side by side. I selected the option "Low" on the CEIKA site, instead of "Extra Low" or "Lift". The pop-out text describes "Low" as adjustable from "around stock height to -10". I have the front at the highest setting and it is sitting super low. I will continue to work through this with CEIKA but so far... I am not impressed. Before: After: All good now with the spacer's added. Thanks for the tips and advice all! JWM, tomo and woot woot 3 Quote Link to comment Share on other sites More sharing options...
JWM Posted 24May, 2023 Report Share Posted 24May, 2023 50 minutes ago, CapnHyaku said: All good now with the spacer's added. Thanks for the tips and advice all! Looks great! tomo and CapnHyaku 2 Quote Link to comment Share on other sites More sharing options...
woot woot Posted 25May, 2023 Report Share Posted 25May, 2023 How the ride and control over bumps? Quote Link to comment Share on other sites More sharing options...
TwoHeadsTas Posted 25May, 2023 Report Share Posted 25May, 2023 On 08/05/2023 at 13:53, CapnHyaku said: So here is a side by side. I selected the option "Low" on the CEIKA site, instead of "Extra Low" or "Lift". The pop-out text describes "Low" as adjustable from "around stock height to -10". I have the front at the highest setting and it is sitting super low. I will continue to work through this with CEIKA but so far... I am not impressed. Before: After: I do like Seal Grey, perhaps that's why I'm onto my third Seal Grey car...... CapnHyaku 1 Quote Link to comment Share on other sites More sharing options...
CapnHyaku Posted 6June, 2023 Author Report Share Posted 6June, 2023 On 25/05/2023 at 10:30, woot woot said: How the ride and control over bumps? It's really hard for me to describe. It is so difficult to describe without two cars to hop in and do the exact same route back to back. I does feel different to before. The most noticable instance was when I recently took a bumby negative camber corner with some speed. It did feel as though the car did not roll as much but instead felt like a more even bounce at all four corners. My neighbour (the racer) is going to share his verdict soon. woot woot 1 Quote Link to comment Share on other sites More sharing options...
