PADM Error
749dark
Porsche PADM is the active engine mounts. Basically electronically controlled to stiffen side to side and when launching. Stops the engine movement when cornering.                              These can fail but might just be a code fault. Try clearing the code and see.         A good independent Porsche mechanic or dealer can check this.
37 minutes ago, sjm said:
Good outcome. Replaced under warranty?
Yep, PCSS replaced it under warranty.
Great service from PCSS... I called them and explained that I have an upcoming track day and they asked the car to come in right away so they can fix it. Found a slot for me.
