ByronBayChris Posted 1May, 2013 Report Share Posted 1May, 2013 I am looking at fixing this myself (gotta start somewhere). Fuse seems fine, as other things on that fuse work. Is the brake pedal microswitch the next most likely issue ? How easy is that for me (who worked in IT for 25 years) to change ? Chris Link to comment Share on other sites More sharing options...
jnr356 Posted 1May, 2013 Report Share Posted 1May, 2013 i'm tipping ecu(maybe you could try someone elses) you haven't given much info does the green light come on? did it just stop working? has the engine been out recently? Link to comment Share on other sites More sharing options...
CarreraG50 Posted 1May, 2013 Report Share Posted 1May, 2013 Broken cable in engine bay, ask me how I know........ Link to comment Share on other sites More sharing options...
ByronBayChris Posted 1May, 2013 Author Report Share Posted 1May, 2013 Jnr No lights at all. Has never worked for me (only had it 5 months) Don't think engine has been out. Link to comment Share on other sites More sharing options...
jnr356 Posted 2May, 2013 Report Share Posted 2May, 2013 yeah,try swapping the ecu with someone for a trial if it turns out to be the problem you can get a change over unit through injectronics,their distributors are repco and bursons Link to comment Share on other sites More sharing options...
Asyd Posted 2May, 2013 Report Share Posted 2May, 2013 i'm tipping ecu(maybe you could try someone elses) you haven't given much info does the green light come on? did it just stop working? has the engine been out recently? I am looking at fixing this myself (gotta start somewhere). Fuse seems fine, as other things on that fuse work. Is the brake pedal microswitch the next most likely issue ? How easy is that for me (who worked in IT for 25 years) to change ? Chris Hi Chris , I had similar problems on my 993. Cavaco's advised this is a common problem and is mostly related to the micro switch. Had the micro switch adjusted and worked for a while when i last checked. I never use it, living inner city and think it might be out of whack again. I,d be curious to know how easy a job it is as I think the switch replacement is the go. My Clutch pedal occassionally does not fully return either and this will affect the micro switch as well. The clutch strut seal is a bit old. cheers Link to comment Share on other sites More sharing options...
T-Man Posted 3May, 2013 Report Share Posted 3May, 2013 i'm tipping ecu(maybe you could try someone elses) you haven't given much info does the green light come on? did it just stop working? has the engine been out recently? I'm no expert by any means, but I thought the cruise control was a separate module and not part of the ECU? Link to comment Share on other sites More sharing options...
