Hughesy Posted 19October, 2014 Report Share Posted 19October, 2014 gday gents, some advice please topped up oil yesterday in the 964, level was spot on. drove to lunch at cottage point in sydney. now some of you may know this area, some great twisty bits etc. car went like a dream. parked for lunch and on return there was a large pool of oil rear drivers side. had a good look and couldnt see a thing or place where the damn oil had come from. the only thing i can think of was that i was parked on the steep incline , rear end lower, i reckon the road is at about a 30 degree incline. car performed beautifully on way home. topped up again with about 500mls. all was good no more leaks after a further half hour run and no leaks this morning. any suggestions??? Link to comment Share on other sites More sharing options...
hugh Posted 19October, 2014 Report Share Posted 19October, 2014 How long did you run the car for before you checked the initial level? Was it up to temperature? Link to comment Share on other sites More sharing options...
Hughesy Posted 19October, 2014 Author Report Share Posted 19October, 2014 Initial check was after 20 min blatt .. seemed up to temp Link to comment Share on other sites More sharing options...
Hughesy Posted 19October, 2014 Author Report Share Posted 19October, 2014 overfill springs to mind, but never happened before.. was it the incline ? not sure. just rechecked all again-- no leaks , engine is hot and oil level is spot on .. i must have overfilled ... cant think of any other reason Link to comment Share on other sites More sharing options...
hugh Posted 19October, 2014 Report Share Posted 19October, 2014 That was all I was thinking, especially if it has been dry prior - make sure you check the on level ground too! Link to comment Share on other sites More sharing options...
Hughesy Posted 19October, 2014 Author Report Share Posted 19October, 2014 thanks hugh, youre a great sounding board, you always respond cheers and thanks again hughesy Link to comment Share on other sites More sharing options...
Russ Posted 19October, 2014 Report Share Posted 19October, 2014 was the patch on the ground your oil? Link to comment Share on other sites More sharing options...
Pauly Posted 19October, 2014 Report Share Posted 19October, 2014 Check your engine for signs of the oil leak. OR someone played a nasty prank. Link to comment Share on other sites More sharing options...
JV911 Posted 19October, 2014 Report Share Posted 19October, 2014 parked on the steep incline Had this happen to a mate's SC once. I'm thinking it was the oil return tubes but I'll confirm Link to comment Share on other sites More sharing options...
JV911 Posted 20October, 2014 Report Share Posted 20October, 2014 confirmed - oil return tube seals when the car was parked on a slope, then oil level was higher than the return tube so it leaked...a lot Link to comment Share on other sites More sharing options...
Hughesy Posted 20October, 2014 Author Report Share Posted 20October, 2014 twas my oil russ.. no pranks pauly reckon i must has put a drop too much in just checked it again... its spot on .. i did add 500ml on return sunday ..soo im guessing my eyes need testing hughesy Link to comment Share on other sites More sharing options...
