michel Posted 21February, 2015 Report Share Posted 21February, 2015 Gents This is also posted on the typ901 forum. As title says I am gong to make a run of factory correct 912/911 LHD RHD passenger and driver side boards. I can also make boards for 356 964 or 993 boards could be done, though not certain they are the same as earlier cars. if they differ id need someone to supply a template. These are factory correct and finished in a matt black stain and to the correct level of finish as per factory - not remarkable but correct. If you want a higher level finish or customised e.g clear finish, or different colour stain, boards with go fast holes, or with exotic finished faces (saddle leather or other) all doable I can also repair /refinish your existing boards. I'm waiting on a better price from timber supplier for a larger order of material - ill confirm pricing based on a min run of 10 next week. If you are in a hurry I can make an individual set or just a side If you would like a set(s) please post here with your specific requirement: Year & model LHD -RHD Sporto A/C cut out (passenger side) Custom requirement Specify pair or a side only Qty. if your car is a LHD -RHD conversion please indicate. I can supply fully finished, part finished (you stain) or plain blank with cutting template. Please specify which Question. someone told me targa boards are slightly different. Can anyone confirm? Thanks michel Link to comment Share on other sites More sharing options...
SimonR Posted 21February, 2015 Report Share Posted 21February, 2015 Michel, I'm in: - 76 911; RHD; no air-con; factory finish; pair. - I'm guessing the 912 could do with a set as well? Simon Link to comment Share on other sites More sharing options...
SM911 Posted 21February, 2015 Report Share Posted 21February, 2015 Interesting point re coupe & targa.. I see that the PET specifies coupe, but doesn't specify targa anywhere else. I don't think the pedal board for my targa is different from a coupe. An anomaly in the PET perhaps? There's a couple of errors/typos elsewhere in the book too. Link to comment Share on other sites More sharing options...
SM911 Posted 21February, 2015 Report Share Posted 21February, 2015 Michel, I'd be happy to look at two: One for the 74 C2.7 (targa), and one for the 77 911 (Coupe). Link to comment Share on other sites More sharing options...
michel Posted 21February, 2015 Author Report Share Posted 21February, 2015 Hi scotty do I need to embroider his n hers? Why targas are a bit different would be the stiffening? I guess due to the partial roof chop. Can't ecplain it otherwise. Scotty could you make templates of your targa boards or post em? Might as well dbl check Promise you'll get em back Anyone have LHD targa boards I could get a template from? even fruitier targa with sporto option Just a heads up this is going ahead due to current interest over in the 901 forum. Thx Michel Link to comment Share on other sites More sharing options...
michel Posted 21February, 2015 Author Report Share Posted 21February, 2015 Simon the 912 does Btw I have been asked to supply boards fully prepped and mounted with clutch stops etc. I'm checking prices and will order a qty . So when your specifying you can add this as an option. Link to comment Share on other sites More sharing options...
SM911 Posted 22February, 2015 Report Share Posted 22February, 2015 Hi scotty do I need to embroider his n hers? Scotty could you make templates of your targa boards or post em? Might as well dbl check Promise you'll get em back No, I don't need embroidery. Yep, I'll look to make you a template. Link to comment Share on other sites More sharing options...
Russ Posted 26February, 2015 Report Share Posted 26February, 2015 I've pulled my drivers side board out if it's any use to you for a template? could probably whip the passenger side one out too Link to comment Share on other sites More sharing options...
michel Posted 31March, 2015 Author Report Share Posted 31March, 2015 Gents ive started to make the boards and Scotty is the first cab (targa) off the rank. Just reconfirm your interest (and requirement) on the thread and I will PM you bank acc details. To secure your order will require a 50% deposit with the balance due on completion. Finished set of RHD boards driver and passenger ready for mounting hardware are $445.00 a set. Std colour - Black New hardware if required will be supplied at cost + $45.00 for fitting. If there are 20 or more confirmed orders the price per set, will be $410, as I can purchase a larger qty of material. For all those who asked for a single side only ill post the price in a tic. Though driver side due to the extra work is more expensive. Postage at cost. Though can combine orders if you can collect from a nominated person. As a comparison from Porsche driver side only is $363.00 + GST. Note: the price is for 911/912 boards. I can supply boards for 356, 914 and 965 and 993's. Yes thats right Porsche still had a bit of 'moggie' in em right up till the demise of the AC Can do special order if you want something a little differentOptions sports purpose - go fast holes coloured or clear finished boards special face veneers composites machined alloy anodizingAlso could anyone who has sporto targa or sporto coupe please supply a template and or crappy board for a template. There's an easter egg in it for you. Am also working on couple of other ideas one which is kind of Butzi meets Eames moment and will post pic once I've finished the prototype and am happy with the making process - Scotty will be the first to give it a go thanks for your interest cheers Michel Link to comment Share on other sites More sharing options...
SteveF Posted 31March, 2015 Report Share Posted 31March, 2015 PM sent Link to comment Share on other sites More sharing options...
michel Posted 1April, 2015 Author Report Share Posted 1April, 2015 Thanks Steve Link to comment Share on other sites More sharing options...
michel Posted 1April, 2015 Author Report Share Posted 1April, 2015 Pricing of single boards are Driver Side $260 Passenger $185 Link to comment Share on other sites More sharing options...
09ELF Posted 2April, 2015 Report Share Posted 2April, 2015 any pics on what these factory reproduction boards look like? Tossing up between factory and aftermarket boards at present Link to comment Share on other sites More sharing options...
SM911 Posted 2April, 2015 Report Share Posted 2April, 2015 Vroom, I'll post pics when I've got mine in the car. Mine are the first boards being produced in this batch (Michel had made a run of them before). Cheers Link to comment Share on other sites More sharing options...
michel Posted 2April, 2015 Author Report Share Posted 2April, 2015 any pics on what these factory reproduction boards look like? Tossing up between factory and aftermarket boards at present These were made in the first run a few years back, now in fishcops car Link to comment Share on other sites More sharing options...
michel Posted 6April, 2015 Author Report Share Posted 6April, 2015 Material been ordered - finished boards will be available late April Link to comment Share on other sites More sharing options...
michel Posted 20June, 2015 Author Report Share Posted 20June, 2015 Link to comment Share on other sites More sharing options...
LeeM Posted 20June, 2015 Report Share Posted 20June, 2015 Nice job Link to comment Share on other sites More sharing options...
