Russ Posted 30June, 2015 Report Share Posted 30June, 2015 i usually put or [image] tags manually around whatever link i'm putting in - this doesn't work anymore, is there an easy fix to embed videos with the new version of the software?I used to have to 'remove' the hyperlink before I could do it, but it seems that option is goneThanksRuss Link to comment Share on other sites More sharing options...
Harvs11 Posted 30June, 2015 Report Share Posted 30June, 2015 Copying the link from the Youtube address bar, not the share/embed link, then pasting directly into your post is the way. It's the same as before. Link to comment Share on other sites More sharing options...
Russ Posted 30June, 2015 Author Report Share Posted 30June, 2015 i seem to get a URL when i do that, not the embed video Link to comment Share on other sites More sharing options...
Airhead Posted 30June, 2015 Report Share Posted 30June, 2015 Inserting code into postsTapping side of nose and small nod.I get what you're saying. Link to comment Share on other sites More sharing options...
Harvs11 Posted 30June, 2015 Report Share Posted 30June, 2015 testing, testing, 1,2,1,2 Link to comment Share on other sites More sharing options...
Harvs11 Posted 30June, 2015 Report Share Posted 30June, 2015 Success, on a Mac at least. The code looks like this Russ, what are you using? Link to comment Share on other sites More sharing options...
D-banger Posted 30June, 2015 Report Share Posted 30June, 2015 I used to do the same as you Russ, now for video I paste in the share link and for pics I use the "Insert other media". Link to comment Share on other sites More sharing options...
Harvs11 Posted 4September, 2015 Report Share Posted 4September, 2015 Aaaargh! I thought I had this nailed. Now when I copy the Youtube address bar then post it in the link all i get is text. Copying the share link creates the playable preview image. testing.... Link to comment Share on other sites More sharing options...
Stew F Posted 13September, 2015 Report Share Posted 13September, 2015 Can I add a pdf file to a post? Or is there another way to share a pdf with everyone? Link to comment Share on other sites More sharing options...
