teknostar Posted 18February, 2016 Report Share Posted 18February, 2016 As above. Anyone had this done?Clearly plenty on the internet, and lots of options out there.Broadly seem to be either go to a local provider and leave the car with them to get tuned (which they will either load a standard AU Spec tune, do themselves in house for a custom tune, or use an overseas tuner to rewrite software overnight) OR buying a port cable (Cobb Access Port / VR Tuned / Softronics etc) and flashing on myself.Buying a cable from a US tuner and getting it tuned remotely is the cheapest option at less than $2k It is then also reversible by myself if needed.I quite like the idea of having a baseline dyno run done followed by installing the tune and doing a second dyno run. I have somewhere i can get this done if I go with the cable route.Has anyone else been through this process / any ideas?Thanks Link to comment Share on other sites More sharing options...
James P Posted 18February, 2016 Report Share Posted 18February, 2016 As above. Anyone had this done?Clearly plenty on the internet, and lots of options out there.Broadly seem to be either go to a local provider and leave the car with them to get tuned (which they will either load a standard AU Spec tune, do themselves in house for a custom tune, or use an overseas tuner to rewrite software overnight) OR buying a port cable (Cobb Access Port / VR Tuned / Softronics etc) and flashing on myself.Buying a cable from a US tuner and getting it tuned remotely is the cheapest option at less than $2k It is then also reversible by myself if needed.I quite like the idea of having a baseline dyno run done followed by installing the tune and doing a second dyno run. I have somewhere i can get this done if I go with the cable route.Has anyone else been through this process / any ideas?Thanks Talk to Fitzgerald Racing in Box Hill they work wonders on late model turbo's Link to comment Share on other sites More sharing options...
teknostar Posted 18February, 2016 Author Report Share Posted 18February, 2016 Talk to Fitzgerald Racing in Box Hill they work wonders on late model turbo's Thanks - I have already. I want to explore other options before making a decision. Link to comment Share on other sites More sharing options...
911GT2 Posted 18February, 2016 Report Share Posted 18February, 2016 Can't go wrong with Cobb, load and datalog for the the performance without local hassle and overpricing! Link to comment Share on other sites More sharing options...
P Posted 5March, 2016 Report Share Posted 5March, 2016 I bought the cobb and tune from protuningfreaks and currently in the process of tuning. No issues thus far, extremely user friendly and different tunes easily uploadable depending on use i.e. valet mode. Great for the price Link to comment Share on other sites More sharing options...
teknostar Posted 16March, 2016 Author Report Share Posted 16March, 2016 Bought a Cobb Accessport V3, and getting a before and after dyno run done today! Looking forward to reporting back shortly!!! Link to comment Share on other sites More sharing options...
teknostar Posted 17March, 2016 Author Report Share Posted 17March, 2016 Cost: $2,600 inc get (Cobb Accessport V3, supplied, installed and two dyno runs)Front driveshafts disconnectedBase line dyno run done 292rwkwStage 1 93 Octane (98 RON) file uploaded. Post upload dyno run 304rwkwBiggest gains were across the middle of the rev range 3000rpm - 5000rpm where a 15% increase was achieved Its not massively different from before the tune as it was already a very fast car, it drives same as stock on part throttle but revs more easily from 3000rpm upwards, with a noticeable increase in mid range torque. I am estimating that it now has about 380kw and 700nm @ flywheel. Link to comment Share on other sites More sharing options...
smit2100 Posted 19March, 2016 Report Share Posted 19March, 2016 Cost: $2,600 inc get (Cobb Accessport V3, supplied, installed and two dyno runs)Front driveshafts disconnectedBase line dyno run done 292rwkwStage 1 93 Octane (98 RON) file uploaded. Post upload dyno run 304rwkwBiggest gains were across the middle of the rev range 3000rpm - 5000rpm where a 15% increase was achieved Its not massively different from before the tune as it was already a very fast car, it drives same as stock on part throttle but revs more easily from 3000rpm upwards, with a noticeable increase in mid range torque. I am estimating that it now has about 380kw and 700nm @ flywheel. Hi Great post with actual back to back numbers. I was expecting a bit more than that even allowing for the US happy hp dyno's https://cobbtuning.atlassian.net/wiki/display/PRS/Porsche+997.1+Turbo+Map+NotesTypical Stage1, Stage2 gains vs Stock Power:Stage1 ACN91 +10% HP / +8% TQ+17% HP / +16% TQStage2 ACN91 +17% HP / +13% TQ+24% HP / +24% TQ Link to comment Share on other sites More sharing options...
teknostar Posted 19March, 2016 Author Report Share Posted 19March, 2016 My power curve was nearly exactly as described by Cobb in the map notes as you have listed above. The gain is mostly in the midrange (17% HP and 16% Tq)There is gain of min 10% and 8% all across the rev range.Best thing is that it drives like stock unless you put your food down hard...Also on Thursday when the dyno runs were done, it was 35 deg and no air specifically directed towards the intercoolers - when driving the power number would be higher. Link to comment Share on other sites More sharing options...
smit2100 Posted 20March, 2016 Report Share Posted 20March, 2016 My power curve was nearly exactly as described by Cobb in the map notes as you have listed above. The gain is mostly in the midrange (17% HP and 16% Tq)There is gain of min 10% and 8% all across the rev range.Best thing is that it drives like stock unless you put your food down hard...Also on Thursday when the dyno runs were done, it was 35 deg and no air specifically directed towards the intercoolers - when driving the power number would be higher. Thanks for disclosing the 35 deg and no fan setup on the intercoolers, that may help to explain why in mind the the peak power levels may be down on what I was expecting to see up top. Did you see any heatsoak of your intercoolers (assuming stock) in the two runs. Link to comment Share on other sites More sharing options...
SteveC Posted 16October, 2016 Report Share Posted 16October, 2016 go for itthe tt is probably one of the best platforms for this, giving a substantial gain for the Area Under Curve so great gains across the entire rev rangeAPR was great but I dont think they are represented here anymore, you'll love itedit: sorry just noticed the date... Link to comment Share on other sites More sharing options...
