Bluboy007 Posted 13May, 2016 Report Share Posted 13May, 2016 How much oil do you guys through. I have a variocam 993 and seems I'm using maybe a litre every 1-2000 kms. Very few short trips and I'm using liquid moly 0-60 Link to comment Share on other sites More sharing options...
tomo Posted 13May, 2016 Report Share Posted 13May, 2016 That sounds about normal Bluboy Link to comment Share on other sites More sharing options...
Bluboy007 Posted 14May, 2016 Author Report Share Posted 14May, 2016 Good to know I've only had her 6 months. Some minor oil leaks from the top covers that were too expensive to fix when I bought it but will change when the engine is out!Thanks for the reassurance Link to comment Share on other sites More sharing options...
Fraz Posted 14May, 2016 Report Share Posted 14May, 2016 @Bluboy007 @tomo is correct. The oil your using might be a bit thin according to the manual. Few pics straght of a 964 owners manual, which I am assuming would be the same for a 993. Link to comment Share on other sites More sharing options...
Peter M Posted 14May, 2016 Report Share Posted 14May, 2016 Blu,Your oil is fine as it satisfies ACEA A4/B4 and therefore meets the HTHS spec that Porsche recommend and has the other characteristics we want too. ( I suspect you're actually using Liqui Moly 10w 60.) If there is a puddle of oil on top of the cooling shroud and below the intake manifold I suspect that is from the oil breather and it may be the result of overfilling your oil tank.If you are doing lots of short trips it's going to be really hard to get any reliable oil consumption data because of the possibility of fuel dilution and getting it to temperature.993's having the most infuriating dipstick in automotive history doesn't help either!Could I suggest you use the exact same location each time to do a check? Your garage if possible otherwise the same location in your local service station forecourt.Could I suggest you forget the dipstick and just aim for "2pm" on your dash gauge. ie not totally full but above halfway. When topping up the oil, turn your parking lights on so you can see the illuminated gauge through the rear window as you sloooooowwwwwllllllllyyyyyyyy add oil once you get close to the 2pm mark.If you find it is overfilled, don't be too hard on yourself as you are not the first! Link to comment Share on other sites More sharing options...
