Stew F Posted 7January, 2017 Report Share Posted 7January, 2017 Whats the easiest way to get the underbody sealer off? Heat gun and a putty knife ? It's on an SC front guard. Then, what product do people use as a replacement? Link to comment Share on other sites More sharing options...
MFX Posted 7January, 2017 Report Share Posted 7January, 2017 I tried a few different methods. The best method in my book is with a 'renovator' tool (you know the oscillating blade type thing) with a flat, flexible scraping blade on it. I used it on my fuel tank and it worked a treat. I went through and finished it up with a wire wheel on the grinder when I was done. Have a look at my 'Fuel Tank' video, you can see a bit of trial and error there. As for the sealer. You can get it from Super cheap but you are best to get a Schutz gun to put it on. Link to comment Share on other sites More sharing options...
Stew F Posted 7January, 2017 Author Report Share Posted 7January, 2017 Thanks @MFX. I did see some gear there last weekend. I'll have to investigate it further. Link to comment Share on other sites More sharing options...
Peter M Posted 7January, 2017 Report Share Posted 7January, 2017 Stew,I have found these very useful:https://www.bunnings.com.au/scotchbrite-paint-rust-stripper-disc-101mm_p6314198 Link to comment Share on other sites More sharing options...
Stew F Posted 7January, 2017 Author Report Share Posted 7January, 2017 Thanks Peter. I've used them before for paint removal. They're great, providing you keep away from panel edges. Link to comment Share on other sites More sharing options...
81SC Posted 7January, 2017 Report Share Posted 7January, 2017 Stew,U-Pol gravitex is a good replacement for the factory underbody sealer. An electric multitool is good for removing the sealer.http://www.ebay.com.au/itm/261198351179?ssPageName=STRK:MESINDXX:IT&_trksid=p3984.m1436.l2649 Link to comment Share on other sites More sharing options...
Stew F Posted 7January, 2017 Author Report Share Posted 7January, 2017 Stew,U-Pol gravitex is a good replacement for the factory underbody sealer. An electric multitool is good for removing the sealer.http://www.ebay.com.au/itm/261198351179?ssPageName=STRK:MESINDXX:IT&_trksid=p3984.m1436.l2649Thanks. Link to comment Share on other sites More sharing options...
LeeM Posted 7January, 2017 Report Share Posted 7January, 2017 I've probably got an old Multi Tool laying around you can have Stew. I change them every 6 months for work Will check in the morning Link to comment Share on other sites More sharing options...
MFX Posted 7January, 2017 Report Share Posted 7January, 2017 Stew,I have found these very useful:https://www.bunnings.com.au/scotchbrite-paint-rust-stripper-disc-101mm_p6314198 I have used these things as well as wire wheels on the sealer, and they do work but hey basically melt their way through it. Great for finishing off, but from experience, the multi tool makes much lighter work or the job ? Link to comment Share on other sites More sharing options...
Stew F Posted 7January, 2017 Author Report Share Posted 7January, 2017 I've probably got an old Multi Tool laying around you can have Stew. I change them every 6 months for work Will check in the morningThanks mate Link to comment Share on other sites More sharing options...
