YellowDieselGolf Posted 6April, 2017 Report Share Posted 6April, 2017 I'm doing some work on the door cards of my car and need some 1/8th inch - (3-4mm) long staples.The hardware stores only stock staples with 6mm or longer legs.Spray adhesive hasn't worked very well. CA isn't much better. Any idea where I can get short staples? Link to comment Share on other sites More sharing options...
LeeM Posted 6April, 2017 Report Share Posted 6April, 2017 Officeworks? The missus says Spotlight, or arts and craft suppliers etc Link to comment Share on other sites More sharing options...
YellowDieselGolf Posted 6April, 2017 Author Report Share Posted 6April, 2017 Sorry Lee - I should have posted a list of where I've tried. Officeworks, spotlight, lincraft, supercheap auto, bunnings, mitre 10, autobarn. I haven't tried specialist art & craft stores so I'll give them a shot today. Thanks for the tip! Link to comment Share on other sites More sharing options...
MARTY Posted 7April, 2017 Report Share Posted 7April, 2017 Try senco I think you can but them online,Good luck Link to comment Share on other sites More sharing options...
AD911S Posted 7April, 2017 Report Share Posted 7April, 2017 Best bet http://www.daleys.com.au/ Link to comment Share on other sites More sharing options...
MFX Posted 7April, 2017 Report Share Posted 7April, 2017 You could go the Home Built option and just trim down a strip of longer ones. They should still work in the staple gun the same. Link to comment Share on other sites More sharing options...
911oclock Posted 7April, 2017 Report Share Posted 7April, 2017 You could go the Home Built option and just trim down a strip of longer ones. They should still work in the staple gun the same.+1 specially if you don't need many. Link to comment Share on other sites More sharing options...
YellowDieselGolf Posted 11April, 2017 Author Report Share Posted 11April, 2017 You could go the Home Built option and just trim down a strip of longer ones. They should still work in the staple gun the same.Thanks for the tips everyone. I found some 4mm paper staples but they were too weak.I then found some 4mm long ones from a local upholsterer, but couldn't source a gun. I tried a few online suppliers but couldn't find any that would suit my stapler. In the end I chopped up a bunch of 8mm staples and then loaded them individually into my staple gun. Tedious!One doors worth, cut to two lengths:Good call MFX. Edit: I tried cutting/grinding/sanding them in strips but they kept falling apart. Link to comment Share on other sites More sharing options...
