Ten Degrees Posted 6January, 2018 Report Share Posted 6January, 2018 On 1/2/2018 at 8:27 PM, dan_189 said: Depends if your 997 has an M96 or an M96 or more identifiably if you have a 3.6 or 3.8 (Carrera S). The M96 you can replace the bearing by dropping the gearbox if you have the 3.8 an entire engine tear down is required to replace the bearing. In an interesting turn of events Porsche have a part number for a replacement M96 IMS bearing. I thought the early 997S motors still have a bearing that could be replaced with the gearbox out? Link to comment Share on other sites More sharing options...
Pokiou Posted 6January, 2018 Report Share Posted 6January, 2018 i like how it says no intermediate shaft... mind you they ALL have the shafts just the bears are now solid like the gt3 and turbo engines. Link to comment Share on other sites More sharing options...
Peter M Posted 6January, 2018 Report Share Posted 6January, 2018 That's true, the 9A1 engines don't have an IMS at all. The camshafts are driven directly by chains from the crankshaft. Link to comment Share on other sites More sharing options...
t888 Posted 6January, 2018 Report Share Posted 6January, 2018 4 hours ago, Ten Degrees said: I thought the early 997S motors still have a bearing that could be replaced with the gearbox out? correct. M96 and M97 had the single row bearings for early (2005) 997 builds. After that they use the double row bearing which is much more reliable, but also much harder to replace. Link to comment Share on other sites More sharing options...
dan_189 Posted 7January, 2018 Report Share Posted 7January, 2018 On 06/01/2018 at 4:18 PM, Ten Degrees said: I thought the early 997S motors still have a bearing that could be replaced with the gearbox out? Its a question of M96 or M97 the base Carrera carried over the M96, the S had the M97 which is a case split to replace the bearing. I've never read of a M97 Carrera S that has had a replacable bearing without a case split. Link to comment Share on other sites More sharing options...
