brian in buddina Posted 4February, 2018 Report Share Posted 4February, 2018 My cigareette lighter does not hold my phone charger very tightly. This causes the charging light to flicker and the charger will fall out easily. I have put a small piece of cardboard to tighten the fit but its not a great solution. Has anyone solved this issue? Link to comment Share on other sites More sharing options...
944s2cab Posted 5February, 2018 Report Share Posted 5February, 2018 Link to comment Share on other sites More sharing options...
Dreamr Posted 5February, 2018 Report Share Posted 5February, 2018 The best solution is to look inside the socket and you will see 2 x tabs that need to be bent back into the socket ... over time they get bent outwards which loosens the hold on the plug being inserted .... Warning ..... either disconnect the battery or pull the fuse before putting anything inside the socket. It's to stop you from blowing the fuse and potentially causing damage ... Link to comment Share on other sites More sharing options...
brian in buddina Posted 5February, 2018 Author Report Share Posted 5February, 2018 2 hours ago, 944s2cab said: sweet! his & hers plug in, no waiting obviously not too concerned about concourse points and keeping it original. either am I! where did you get it? Dreamer, thx I will give it a try. Link to comment Share on other sites More sharing options...
944s2cab Posted 5February, 2018 Report Share Posted 5February, 2018 4 minutes ago, brian in buddina said: sweet! his & hers plug in, no waiting obviously not too concerned about concourse points and keeping it original. either am I! where did you get it? Dreamer, thx I will give it a try. I made it, bought a cigar lighter adapter, dismantled, made hole in spare blanking plate, fitted, soldered some wires and connected it to stereo wiring Link to comment Share on other sites More sharing options...
brian in buddina Posted 5February, 2018 Author Report Share Posted 5February, 2018 nice job, well done Link to comment Share on other sites More sharing options...
TINGY Posted 5February, 2018 Report Share Posted 5February, 2018 4 hours ago, brian in buddina said: My cigareette lighter does not hold my phone charger very tightly. This causes the charging light to flicker and the charger will fall out easily. I have put a small piece of cardboard to tighten the fit but its not a great solution. Has anyone solved this issue? 3 944's I've had have done the same thing. 2 hours ago, 944s2cab said: I made it, bought a cigar lighter adapter, dismantled, made hole in spare blanking plate, fitted, soldered some wires and connected it to stereo wiring When do i book you in to do mine? Link to comment Share on other sites More sharing options...
944s2cab Posted 5February, 2018 Report Share Posted 5February, 2018 3 hours ago, TINGY944 said: 3 944's I've had have done the same thing. When do i book you in to do mine? I'll see if I've got a spare blanking plate in the garage, would you prefer dash or console? (different blanking plates), might be a few weeks or more as I'm trying to do the suspension, brakes and bearing for PCNSW supersprint on 4th March Link to comment Share on other sites More sharing options...
brian in buddina Posted 5February, 2018 Author Report Share Posted 5February, 2018 we might need a photo exposé on this build! Link to comment Share on other sites More sharing options...
TINGY Posted 5February, 2018 Report Share Posted 5February, 2018 1 hour ago, 944s2cab said: I'll see if I've got a spare blanking plate in the garage, would you prefer dash or console? (different blanking plates), might be a few weeks or more as I'm trying to do the suspension, brakes and bearing for PCNSW supersprint on 4th March All good mate, my tongue was firmly in my cheek, i don't want take you away from your work on your car anyway. I don't want to lose concourse points either Link to comment Share on other sites More sharing options...
Jason E Posted 9February, 2018 Report Share Posted 9February, 2018 I bought one of the very small double usb plugs. I think it's belkin (maybe Gecko). Fits straight in & never popped out. I'll take a picture & text it to you. Link to comment Share on other sites More sharing options...
