AC78 Posted 16April, 2018 Report Share Posted 16April, 2018 Team I am in the process of installing a used Dansk muffler on my SC and the exhaust pipe doesn't align properly with the outlet on the rear valance. Instead of the pipe coming out the centre of the outlet, it sits hard up against the inside edge. The Dansk is attached to a set of SSIs and there is no further adjustments to be made to change the position of the muffler. It looks like the exhaust pipe has been modded at some point so I need to bend it about 1cm to get it off the paint and towards the centre of the outlet. Is this something I can safely do myself - say by heating up the pipe with a propane torch and bending it with a tight fitting axe handle, or is it best left to an exhaust shop? Link to comment Share on other sites More sharing options...
P-Kay Posted 16April, 2018 Report Share Posted 16April, 2018 I tried heating, but in the end had to unfortunately admit defeat and took it to a shop. Purely because I did not have stainless wire for the mig - yes, they ended up cutting and re-welding the tip to the correct location Good luck Link to comment Share on other sites More sharing options...
LeeM Posted 16April, 2018 Report Share Posted 16April, 2018 I'd handball it to a shop mate. That's their job ? Link to comment Share on other sites More sharing options...
Simonk Posted 18April, 2018 Report Share Posted 18April, 2018 Can you loosen the SSIs and jiggle them to the left a touch. I small amount of movement in them might translate to a lot of movement at the exhaust top. Link to comment Share on other sites More sharing options...
Stew F Posted 18April, 2018 Report Share Posted 18April, 2018 You most likely won't be able to keep enough heat in it to be able bend it successfully, unless you do it with an oxy acetylene torch. Easier to take it to a muffler shop. They'll probably just cut it off and re-weld it. Link to comment Share on other sites More sharing options...
AC78 Posted 18April, 2018 Author Report Share Posted 18April, 2018 Thanks guys, i'm taking it to a shop. I will also get them to cut off the rolled tip, which reminds me of a condom. The Dansk doesn't look nearly as good as the Monty I had. Link to comment Share on other sites More sharing options...
