dobbo Posted 3September, 2018 Report Share Posted 3September, 2018 While I had the battery out the other day I cleaned up fuse 9 and swapped over defrost relay with the blower fan relay as my blower hasn't worked from day one of ownership. Blower now working and defrost now not working so I want to buy two new relays. Has anyone purchased these and if so where and how much? Thanks in advance Dobbo. Link to comment Share on other sites More sharing options...
brian in buddina Posted 3September, 2018 Report Share Posted 3September, 2018 dobbo If your so inclined you can trying fixing your relay. I had a similar issues in a previous thread "radiator fan run on" in front engine. @Peter M suggested this solution: http://www.911chips.com/dmerelay.html It wasn't the dme that was the issue but the instructions were based on using that relay as an example of wht to do. I put extra solder on the back of the circuit board. It worked for me. I bought a new soldering iron of higher wattage and a sharp working point. good luck Link to comment Share on other sites More sharing options...
ANF Posted 3September, 2018 Report Share Posted 3September, 2018 What you are after is this I believe, a standard 4 pin 40a relay, available just about everywhere. Take yours out and make sure you buy one with the same circuit diagram on the side (ie 30 to 87 circuit). Maybe about $10..... eccosafetygroup.com.au/wp-content/uploads/pdfs/am/Britax_Relays.pdf Link to comment Share on other sites More sharing options...
Dreamr Posted 4September, 2018 Report Share Posted 4September, 2018 1 hour ago, ANF said: What you are after is this I believe, a standard 4 pin 40a relay, available just about everywhere. Take yours out and make sure you buy one with the same circuit diagram on the side (ie 30 to 87 circuit). Maybe about $10..... eccosafetygroup.com.au/wp-content/uploads/pdfs/am/Britax_Relays.pdf This is what I've always loved about this forum over the past number of years .... The knowledge of different people about all different facets of things and the sharing of such information .. Great bit of information and thanks for sharing @ANF ... ? Link to comment Share on other sites More sharing options...
ANF Posted 4September, 2018 Report Share Posted 4September, 2018 14 minutes ago, Dreamr said: This is what I've always loved about this forum over the past number of years .... The knowledge of different people about all different facets of things and the sharing of such information .. Great bit of information and thanks for sharing @ANF ... ? That's the whole point isn't it, you learn something and then pass it on to the next person who may need it Link to comment Share on other sites More sharing options...
dobbo Posted 4September, 2018 Author Report Share Posted 4September, 2018 Thanks ANF have got a supercheap voucher for fathers day will try them first. Link to comment Share on other sites More sharing options...
Timm Posted 4September, 2018 Report Share Posted 4September, 2018 9 hours ago, brian in buddina said: dobbo If your so inclined you can trying fixing your relay. I had a similar issues in a previous thread "radiator fan run on" in front engine. @Peter M suggested this solution: http://www.911chips.com/dmerelay.html It wasn't the dme that was the issue but the instructions were based on using that relay as an example of wht to do. I put extra solder on the back of the circuit board. It worked for me. I bought a new soldering iron of higher wattage and a sharp working point. good luck This has worked for me as well in the past. Link to comment Share on other sites More sharing options...
