944s2cab Posted 28April, 2019 Report Share Posted 28April, 2019 Hi all, I'm looking at new hoses for the cab. if I have a complaint about the brakes it is that the pedal feels spongey even though I've flushed and bled the brakes, What are peoples experiences Link to comment Share on other sites More sharing options...
LeeM Posted 28April, 2019 Report Share Posted 28April, 2019 Only from bike my racing experience, Goodridge braided lines made a great difference for me. Not sure for cars, but I'm sure they would make a difference to initial bite and pedal feel. Check your state regs, yet I think they're either illegal or require an engineers report for rego/insurance purposes...or just fit them and not tell anyone 😁 Link to comment Share on other sites More sharing options...
944s2cab Posted 28April, 2019 Author Report Share Posted 28April, 2019 5 hours ago, LeeM said: Only from bike my racing experience, Goodridge braided lines made a great difference for me. Not sure for cars, but I'm sure they would make a difference to initial bite and pedal feel. Check your state regs, yet I think they're either illegal or require an engineers report for rego/insurance purposes...or just fit them and not tell anyone 😁 I've checked and Goodridge line are ADR compliant, so I think I'll order a set Link to comment Share on other sites More sharing options...
LeeM Posted 29April, 2019 Report Share Posted 29April, 2019 1 hour ago, 944s2cab said: I've checked and Goodridge line are ADR compliant, so I think I'll order a set Cool mate. From what I've learnt with bikes and braided lines, a lot of brands fail the 'whip test' where some stretch and some don't, the same as carbon ones. I think Goodridge were the pioneers with having some sort of coating or protection on them to reduce the stretching of the lines, and they've always had a good name. Strange when you think standard rubber brake lines deteriorate much quicker than braided does Link to comment Share on other sites More sharing options...
ANF Posted 29April, 2019 Report Share Posted 29April, 2019 I wonder what difference you would get in just replacing old rubber lines with new rubber lines, has to be worth thinking about? Also as a rubber line gets older you can see it deteriorating, you cannot see this with a braided line, this would be my only concern.... Link to comment Share on other sites More sharing options...
Harvs11 Posted 29April, 2019 Report Share Posted 29April, 2019 4 hours ago, 944s2cab said: I've checked and Goodridge line are ADR compliant, so I think I'll order a set I bought a set of these for my SC. No complaints. From memory, the hoses have a tag with ADR approval if sourced from a local authorised distributor. Goodridge hoses have protective outer casing over the braiding which I believe is an ADR criteria. One issue that vehicle inspectors may have is being able to visually inspect for damaged hoses. Clear casing protects and allows inspection of the braiding. Having properly tagged compliant hoses would help. Link to comment Share on other sites More sharing options...
Jason E Posted 29April, 2019 Report Share Posted 29April, 2019 When Buchanans did the refresh on my car they installed new braided brake lines. I've had no complaints & have had cause to jam the anchors on a few times with nil impacts so good in my books. Link to comment Share on other sites More sharing options...
Harvs11 Posted 5May, 2019 Report Share Posted 5May, 2019 On 29/04/2019 at 19:16, Jason E said: I've had no complaints & have had cause to jam the anchors on a few times with nil impacts so good in my books. SC's typically have a softer pedal thanks to the booster. I replaced the lines as the brakes were very spongy due to soft 30 year old hoses. The braided hoses had an immediate effect and greatly improved the pedal feel. I can modulate the brakes from a light touch to full hard braking without losing control. The limit is easily reached and lock ups are rare, even in the wet. Link to comment Share on other sites More sharing options...
944s2cab Posted 6May, 2019 Author Report Share Posted 6May, 2019 I believe that to be ADR compliant the lines only have to be meet one of the major standards Link to comment Share on other sites More sharing options...
