mark2559 Posted 8May, 2023 Report Share Posted 8May, 2023 (edited) Following the restomod of my 964 (see elsewhere in this forum - RUF Hot Rod), I have quite a few parts no longer required. The car was a Japan import Tiptronic with 103,000 km showing. Available Parts: 1. Brake Calipers - full set Front & Rear - fully operational and in good condition (if you want the rotors, you get them for free) 2. Front Suspension complete (less Control arms) - yes I retained the control arms for my build, but everything else included. Struts, Springs, Strut Mounts, Sway Bar, Drop Links, Dampers, Wheel Carrier Uprights, Tie Rod Ends etc. Straight and in fully serviceable condition. Rear suspension dampers + rear sway bar + drop links are also available. 3. Full Exhaust system - from exhaust manifold to exhaust tip - mufflers (primary + secondary), catalytic converter, heat exchangers, exhaust tip - the full system. Honestly in V. good condition. 4. Original Pistons and Barrels (full matched set removed and correctly stored (in sets) from the 3.6 litre engine + Con Rods 5. Complete inlet tract (yes from Air Cleaner to Inlet Port) - the car is a 1991, so the inlet plenums are the "plastic" variety and the throttle body the "late" type - I will only sell this as a complete inlet system. 6. ECU for engine - again was off a fully running car appears to be completely A1 + ECU metal shields (as bolted under seat and above ECU for dust protection. 7. Front Fog Lights - undamaged and in A1 condition + Indicators / Reflectors + "In-Fill" pieces 8. Original Headlights - undamaged and in A1 condition 9. Original Oil Cooler - undamaged and in Serviceable condition 10. A/C Parts - Condenser + Evaporator + Brackets 11. Dual Distributor + Dual Coil Pack + Leads = SOLD. 12. Tiptronic Transmission - Complete including ECU (car only did 103k km and was fully functioning prior to project) even have the oil lines to front of car + transmission oil cooler (No Photos, but available if required) I have not priced these as to be honest I have not researched the pricing. Upon receipt of reasonable offers, I will check prices and respond to each enquiry promptly. I will take reasonable offers as I really would like to see these go to good homes (and prevent clutter in my garage). Yes you can post offers directly to this forum or PM me. If you have any other part request - let me know as I may have it available Edited 4December, 2023 by mark2559 Marked [SOLD] Items Harsh and Mike D'Silva 2 Quote Link to comment Share on other sites More sharing options...
icu_jimmy Posted 9May, 2023 Report Share Posted 9May, 2023 PM sent. Quote Link to comment Share on other sites More sharing options...
mark2559 Posted 6June, 2023 Author Report Share Posted 6June, 2023 Exhaust System Photos: To purchase these parts from FVD, Design911 or other genuine parts would set you back over$12k ... I will sell the complete system for $3,200. Oldskl60 1 Quote Link to comment Share on other sites More sharing options...
mrar Posted 2July, 2023 Report Share Posted 2July, 2023 Purchased some parts off Mark just recently, all as described/checked before sent/well packed. Even helped out with the post, straight up guy to deal with. Thanks Mark.👍 mark2559 and Oldskl60 2 Quote Link to comment Share on other sites More sharing options...
mark2559 Posted 17August, 2023 Author Report Share Posted 17August, 2023 Most parts as above still available. Quote Link to comment Share on other sites More sharing options...
