brian in buddina Posted 21November, 2023 Report Share Posted 21November, 2023 My headlight lens is held in by 3 screws which go through a plastic bit to hold the lens in place. One plastic bit has disintegrated, so the lens flops about as its only restrained by 2 screws and their plastic bits. Checking the Porsche katalogue the plastic bits are shown in the “part 1A retaining frame” assembly, but does not have an individual part number for the 3 plastic bits. Has anyone come across this before? Is it a common VW part? Or is there a simple fix eliminating the plastic bits altogether and use a nut, as a lock nut, on the backside of where the plastic bit would have been. This would lock the headlight lens & assembly in place? tomo 1 Quote Link to comment Share on other sites More sharing options...
bear924 Posted 21November, 2023 Report Share Posted 21November, 2023 Hey Brian. My little itzy bitzy bits are metal on my 924. You could potentially pick up the brackets from someone wrecking a real Porsche and never have to deal with this again. Rob and micknine01 1 1 Quote Link to comment Share on other sites More sharing options...
jakroo Posted 21November, 2023 Report Share Posted 21November, 2023 use some regular hex or even wing nuts, before and after the bracket. Snug them up tight and maybe some Loctite when you have them adjusted and they should be okay. Rob 1 Quote Link to comment Share on other sites More sharing options...
Jaffar Posted 22November, 2023 Report Share Posted 22November, 2023 A nutsert of the appropriate size could work. Just be sure to use aluminium as they are softer. Rob 1 Quote Link to comment Share on other sites More sharing options...
bergerac Posted 28November, 2023 Report Share Posted 28November, 2023 Design911 sells them I'm pretty sure Quote Link to comment Share on other sites More sharing options...
