Buchanan Automotive Posted 1April, 2018 Report Share Posted 1April, 2018 50 years ago (1968 ) was the debut of the 2nd generation 8 cylinder Porsche engine , the 908 , 3 litre eight cylinder chain driven double overhead cam per bank with two valves per cylinder & this engine was quite different to the first generation 8 cylinder Porsche engine the type 753 ( 1.5 L 8 cyl ) & the same engine with more capacity the 771( 2.0L 8 cyl) & 771/1 ( 2.2L 8 cyl )But first a quick look at the first 8 cylinder engine was the type 753 , it was a 1.5L( 1500cc) flat 8 (2 valve DOHC ) engine designed to go into Porsche's only ever "pure" Formula One car in 1962 ( car type 804 ) , it only raced a few Formula One races in 1962 & it even won the French Formula One race & that was the only time , Porsche withdrew from Formula One to concentrate on sports car racing Whats technically interesting about this 8 cylinder engine was the way it drove its DOHC ( double overhead camshafts ) via bevel drive shafts ( a bit like a 1960's/1970's Ducati motor cycle engine )& similar to Porsche's 4 cylinder Carrera "Fuhrmann " DOHC engines , so this means it was very time consuming to make & to get everything to stay together , everything had to be shimmed to get the correct preloads for the multiple bevel drive gears & their respective bearings & expected preloads & clearances ( cold & hot ), so there was a lay shaft driven by the crankshaft and this layshaft in the crankcase also drive the two ignition distributors & the crane drive ( take off ) for the large top mounted cooling fan , from this intermediate shaft ( centre / top of engine crankcase ) two of the bevel drive shafts went off at 90 degrees to the centre of the cam boxes to drive the inlet cams ( L & R ) with their respective bevel gears . shims / bearings & then from the inlet cams & going off al another 90 degrees , but this time straight down are two more bevel drive shafts going to the exhaust cams with their respective bevel gears / bearings / shims Magnificently complicated , but durable if all the clearances & preloads are massively time consumingly done This above 8 cylinder engine ( one year only raced as a 1.5L ) was modified over the next few years for use in sports car racing & had grown to 2.0L with mechanical fuel injection ( engine type 771 ) & then later as a 2.2 L engine ( engine type 771/1 ) , these 8 cylinder Porsche engines were used in sports car & hill climb & Targa Florio competitions & were very successful in Porsche car Types = 718 , 904 , 906 , 909 , 910 , One of the standouts for me is the 1967 Porsche 910/8 Bergspyder , this Porsche ( Hill climb special ) weighed in at 410KG( Total car weight) its 1,981cc 8 cylinder NA engine gave 270HP at 9,000RPM So these beautifully complicated 8 cylinder Porsche engines competed and won numerous sports car / hill climb events from 1962 to 1968 , the last hurrah for this engine was victory in the 1968 Sebring 12 hour & the Targa Florio in a Porsche 907 & then off to the Porsche museum for this engine & the last Porsche engine to use the bevel / shaft drive DOHC In 1968 ( 50 years ago ) came the 2nd new 8 cylinder Porsche engine , the 3.0 Litre 908 engine type 300HP to 360HP in NA form , this was the a simpler chain drive to the DOHC ( much less expensive to make as compared to the type 771 ) and being air oil cooled it was still only 2 valves per cylinder , this engine went on being used in competition right up where this engine was eventually turbo charged ( like its big brother the 12 cylinder 917 engine ) which kept its ability to keep competing in events for years & years , a de tuned version of this 3.0L 8 Cylinder engine was installed into 2 separate Porsche 914's for evaluation purposes . One 914/8 was built for Porsche's chief technician at the time Ferdinand Piech ( this one was not street registered as the engine was full race trim ), the other 914/8 was given to Dr Ferry Porsche for his 60th Birthday , this was more suitable for road conditions and was fitted with carby's & air-filters and produced 260HP The intesting thing about the 908 ,8 cylinder engine was it was a much simpler engine( more cost effective to produce ) as opposed to the previous very complicated first generation 8 cylinder engine ( type 753 / 771 ) that was only ever going to be a very low volume race engine . The 908 8 cylinder chain drive, twin cam per bank engine was much more aligned with other Porsche road engines in relative simplicity , what I mean they is its not as simple as a VW beetle push rod engine , but its a whole lot simpler than the first generation bevel drive 8 cylinder engines to produce & maintain , so much so ( as mentioned above ) the 908 , 8 cylinder engine was installed in two Porsche 914 road cars in 1969 , and of course because the 908 engine had the more common / much less expensive to manufacture "road car" crankshaft oiling ( pressure" delivery system to the con-rod bearings ) radial feed & being that the 908 engine was a true "Flat Eight" boxer engine , meaning one dedicated crank journal per con-rod , which made the crankshaft a bit longer than it needed to be & made oil pressure supply to the centre of the crank a bit more difficult with its "road like" radial feed crank design , and to keep the con rod bearings from destroying them selves at high engine RPM the engine required massive oil pressure & naturally this means a very high viscosity engine oil to keep the oil pressure sufficient , where as its ( one year later ) big brother 917 12 cylinder engine was a true no expense spared race engine with a dedicated axial feed crankshaft & a more modern & compact 2 con-rods per crank journal making the 917 engine a 180 deg V 12 & " Not" a boxer engine like the road going 911 engine or the 908 engine Here are some notes written by Hans Mezger ( the designer of quite a few Porsche race engines including the famous 12 cylinder 917 engine } Because the 911 air/oil cooled engine used for road and competition had Radial feed into the crankshaft to the con-rod bearings , the Oil Pressure needed at 9,000RPM was 70 Lbs Sq " ( 5kp/cm/2) MIN pressure at max racing oil temp ( thats high but necessary because of centrifugal forces) The 908 ( 8 cylinder ) 3.0L air/oil cooled race engine had Radial feed to the con-rod bearings , to overcome con-rod bearing issues in racing the crankshaft required at 9,000RPM was 100 Lbs Sq " ( 7 Kp/cm/2 ) Min oil pressure at Max racing oil temp ( Thats Massive Oil Pressure , but necessary because of centrifugal forces ) Hence why proper race engines like the 917, 12 cylinder engine had Axial feed & with axial feed there are NO centrifugal forces pushing away the oil trying to get into the crank , so with Axial feed the 917 engine only required at 10,300 RPM was 34Lbs Sq " ( 2.3 Kp/cm/2 ) Oil pressure , thats quite low , but all thats needed because centrifugal forces were not effecting the oil pressure Regards Bruce Buchanan Buchanan Automotive Link to comment Share on other sites More sharing options...
tazzieman Posted 1April, 2018 Report Share Posted 1April, 2018 Some things on the bucket list aren't going to happen. ***Sigh*** Glorious engine. Makes you realise what a utterly boring mechanical age we are entering. I bought this today https://www.nytimes.com/2016/12/05/books/revenge-of-analog-david-sax.html Link to comment Share on other sites More sharing options...
firstone Posted 1April, 2018 Report Share Posted 1April, 2018 Careful, the machines are keeping record. David Sax aka John Connor. ? Link to comment Share on other sites More sharing options...
tazzieman Posted 1April, 2018 Report Share Posted 1April, 2018 4 hours ago, firstone said: Careful, the machines are keeping record. David Sax aka John Connor. ? Scissors , paper, rock. Them machines don't stand a chance. Link to comment Share on other sites More sharing options...
Raven Posted 2April, 2018 Report Share Posted 2April, 2018 Google and Apple are Sky Net .................. Link to comment Share on other sites More sharing options...
Troubleshooter Posted 3April, 2018 Report Share Posted 3April, 2018 On 01/04/2018 at 8:07 PM, tazzieman said: I bought this today https://www.nytimes.com/2016/12/05/books/revenge-of-analog-david-sax.html That available on E-Book? Link to comment Share on other sites More sharing options...
tazzieman Posted 3April, 2018 Report Share Posted 3April, 2018 16 minutes ago, Troubleshooter said: That available on E-Book? What's an e-book? Some sort of native bird? Link to comment Share on other sites More sharing options...
Ozvino Posted 3April, 2018 Report Share Posted 3April, 2018 4 hours ago, Troubleshooter said: That available on E-Book? yes, available in Kindle format - kind of ironic me thinks.... Link to comment Share on other sites More sharing options...
tazzieman Posted 6April, 2018 Report Share Posted 6April, 2018 On 01/04/2018 at 1:31 PM, Buchanan Automotive said: The interesting thing about the 908 ,8 cylinder engine was it was a much simpler engine( more cost effective to produce ) as opposed to the previous very complicated first generation 8 cylinder engine ( type 753 / 771 ) that was only ever going to be a very low volume race engine . The 908 8 cylinder chain drive, twin cam per bank engine was much more aligned with other Porsche road engines in relative simplicity , what I mean they is its not as simple as a VW beetle push rod engine , but its a whole lot simpler than the first generation bevel drive 8 cylinder engines to produce & maintain , so much so ( as mentioned above ) the 908 , 8 cylinder engine was installed in two Porsche 914 road cars in 1969 "Described by driver Gerard Larrouse as "not really a racing engine at all" "A constraint on its design was that Ferry Porsche asked that it not be unsuitable for use in a production car. His nephew Ferdinand Piech would indeed propose production cars using it" - KLudvigsen It took several changes of firing order to give of its best Must be time for some sound! Link to comment Share on other sites More sharing options...
