Mike D'Silva Posted 22May, 2013 Report Share Posted 22May, 2013 my 06 Cayman has old dirt underneath.. all the nice aluminium bits aren't shiny, but brown with dirt. My domestic pressure cleaner took off a small amount... but what's a good way to get the really old stuff off? Do you use a spray on cleaner that breaks it down then hoses off?? Link to comment Share on other sites More sharing options...
Caver Posted 22May, 2013 Report Share Posted 22May, 2013 WD40 is the magic element....check out earlier posts....started on cleaning wheels....moved to cleaning underneath. Link to comment Share on other sites More sharing options...
tazzieman Posted 22May, 2013 Report Share Posted 22May, 2013 Crud is protective! Ask any Land Rover owner You're not going all concours on us are you? Link to comment Share on other sites More sharing options...
Mike D'Silva Posted 24May, 2013 Author Report Share Posted 24May, 2013 so it seems that what I thought was crud, was actually applied by the factory to protect from corrosion???? Link to comment Share on other sites More sharing options...
T-Man Posted 24May, 2013 Report Share Posted 24May, 2013 Cosmoline is your protective freind!!!!! Back when the 993s were made Porsche must have bought a ton of it. I reckon I could drop 50kg of weight off the car if I got rid of it all. Link to comment Share on other sites More sharing options...
Russ Posted 25May, 2013 Report Share Posted 25May, 2013 Yep, if its a waxy brown thing its a factory applied protection Link to comment Share on other sites More sharing options...
1977930 Posted 1September, 2013 Report Share Posted 1September, 2013 Im sure handling and performance is improved with a clean car, would be interesting if you did a 0-60 before and after and let us know Link to comment Share on other sites More sharing options...
jnr356 Posted 1September, 2013 Report Share Posted 1September, 2013 if you want it off,do it now ,because in a few years time it will be baked on and very difficult to remove.i used to remove it on pre-deliveries,most other tech's didn't.the salt on the ships used to leave white speckles on components not covered in wax,sometimes tops of engines had salt affected areas.great fun working on suspension,g/boxes, etc with it still on,free hair removalfor removal of dirt stains and mild oil leaks i use a product called G101 from a company called autosmart(just be careful of wheels and paint,can stain raw ally eg forged 928 rims and will strip the polish off your exterior paint ,prevented by "sudsing up" beforehand) Link to comment Share on other sites More sharing options...
Chris-p Posted 1September, 2013 Report Share Posted 1September, 2013 +1 on the G101. A very close friend was the Australian master franchise owner of autosmart and I have used it a lot and can recommend. But Caver's recommendation on WD40 is a good one too... C Link to comment Share on other sites More sharing options...
