Peter M Posted 17August, 2013 Report Share Posted 17August, 2013 http://liftbars.com/ Link to comment Share on other sites More sharing options...
Russ Posted 17August, 2013 Report Share Posted 17August, 2013 this is interesting, I couldn't really tell from the site - wonder if they work on older 911's also what is the big benefit? that you don't have to know where to put axle stands? Link to comment Share on other sites More sharing options...
T-Man Posted 17August, 2013 Report Share Posted 17August, 2013 I really like the idea of these. Very clever. Link to comment Share on other sites More sharing options...
Chris-p Posted 17August, 2013 Report Share Posted 17August, 2013 I agree T. Very clever.... Link to comment Share on other sites More sharing options...
oldblade Posted 17August, 2013 Report Share Posted 17August, 2013 so simply why hasnt it been thought of before Link to comment Share on other sites More sharing options...
wasserkuhl Posted 17August, 2013 Report Share Posted 17August, 2013 this is interesting, I couldn't really tell from the site - wonder if they work on older 911's also what is the big benefit? that you don't have to know where to put axle stands? They would work well on the 924/944/968/928 models as they can be located in the holes that are jacking points in the body. You could fashion a similar bar for 911's pre 964, that would have to have flat pads at each end that sit at the corners of the floor pan, however the problem is that the bar would have to be stepped to clear the pinch welds of the pan. It could be done but would take alot of careful designing to get it to be both stable and secure. Then again, its not much of a problem to lift up a 911 as you can easily place the jack stands on both the front and rear torsion bar tubes. Link to comment Share on other sites More sharing options...
Russ Posted 17August, 2013 Report Share Posted 17August, 2013 thanks wasser, I was wondering what i'd missed (cause when I've had mine on the jack it lifts a side at a time) can see the use for the other models now though Link to comment Share on other sites More sharing options...
T-Man Posted 17August, 2013 Report Share Posted 17August, 2013 Then again, its not much of a problem to lift up a 911 as you can easily place the jack stands on both the front and rear torsion bar tubes. What's a torsion bar tube??? Link to comment Share on other sites More sharing options...
Dubai944 Posted 17August, 2013 Report Share Posted 17August, 2013 Interesting idea but I don't see the need for a 944 at least. I do the same thing jacking the 944 at the single central jack point. Then pop the stands under the front and rear jack points.Plus you would need more clearance. Link to comment Share on other sites More sharing options...
wasserkuhl Posted 17August, 2013 Report Share Posted 17August, 2013 What's a torsion bar tube??? Ok, I should have specified this by saying a pre-964 911. Or were you taking the p*ss? Link to comment Share on other sites More sharing options...
T-Man Posted 18August, 2013 Report Share Posted 18August, 2013 Ok, I should have specified this by saying a pre-964 911. Or were you taking the p*ss?Taking the p*ss mate! Link to comment Share on other sites More sharing options...
Harvs11 Posted 18August, 2013 Report Share Posted 18August, 2013 Am I missing something? I don see the need for a bar with pads for pre-964 911's. Lift both wheels per side using the centre jack point. You can use the standard jack or a trolley with an adapter. Once it's up high enough jack stands go in. Link to comment Share on other sites More sharing options...
Russ Posted 18August, 2013 Report Share Posted 18August, 2013 Am I missing something? I don see the need for a bar with pads for pre-964 911's. Lift both wheels per side using the centre jack point. You can use the standard jack or a trolley with an adapter. Once it's up high enough jack stands go in. about half the thread apparently zing (sorry, couldn't help it) Link to comment Share on other sites More sharing options...
Harvs11 Posted 18August, 2013 Report Share Posted 18August, 2013 thanks wasser, I was wondering what i'd missed (cause when I've had mine on the jack it lifts a side at a time) can see the use for the other models now though fair nuff i missed your post. Link to comment Share on other sites More sharing options...
Guest hepkat63 Posted 9January, 2014 Report Share Posted 9January, 2014 pardon my tight a*** nature, but could you not just get a piece of 50mm * 50MM square RHS, screw in some bolts at each end in the correct place to line up with the jack lifting holes and achieve the same thing? Link to comment Share on other sites More sharing options...
Peter M Posted 9January, 2014 Author Report Share Posted 9January, 2014 Yes! Link to comment Share on other sites More sharing options...
webrest Posted 9January, 2014 Report Share Posted 9January, 2014 Am I missing something? I don see the need for a bar with pads for pre-964 911's. Lift both wheels per side using the centre jack point. You can use the standard jack or a trolley with an adapter. Once it's up high enough jack stands go in. Some of the later 3.2's had lift points apparently. Doug's late in 3.2 series for one. I can guarantee that as I have had it up on my hoist a used them to put the lift arms under. As for anything earlier in the 911 series I reckon you can forget it, no points on them for this whiz bang bar to fit in. The thing that confused me though is that on his website he clearly shows what looks to be a very early 911 being raised. ??? If I'm wrong please set me straight Dave Link to comment Share on other sites More sharing options...
webrest Posted 9January, 2014 Report Share Posted 9January, 2014 What's a torsion bar tube??? Elitist snob. You and your fancy coil springs. Some of us may prefer 1930's technology. Dave Link to comment Share on other sites More sharing options...
