SteveT Posted 6June, 2014 Report Share Posted 6June, 2014 Hi all, can someone tell me what this little toggle switch under the LH side of my dash near the steering column does? Bearing in mind that it is a 1976 Targa. The only reference that I can find anything like it is a switch for an electric sunroof but I sure don't have one of those. And I presume it's not for an ejector seat. It's the switch marked in the pic, under the oil pressure - temp gauge, above the blanking plug. Link to comment Share on other sites More sharing options...
Russ Posted 6June, 2014 Report Share Posted 6June, 2014 flicks between left and right when you have electric mirrors the one between your temp and oil level does wiper speed on intermittent Link to comment Share on other sites More sharing options...
tazzieman Posted 6June, 2014 Report Share Posted 6June, 2014 I'll bet it's in your user manual. You have got one of those , surely? Link to comment Share on other sites More sharing options...
Russ Posted 6June, 2014 Report Share Posted 6June, 2014 from an Carrera 3.2 but it's mostly the same Link to comment Share on other sites More sharing options...
SteveF Posted 6June, 2014 Report Share Posted 6June, 2014 I wonder what 26 does - Switch for intensive cleaning? This could save me allot of time on the weekend. Link to comment Share on other sites More sharing options...
SteveT Posted 6June, 2014 Author Report Share Posted 6June, 2014 Thanks Russ, makes sense. I was wondering how to adjust the RH mirror! Link to comment Share on other sites More sharing options...
SteveT Posted 6June, 2014 Author Report Share Posted 6June, 2014 I'll bet it's in your user manual. You have got one of those , surely? I have a PDF version, no history with this car at all. Link to comment Share on other sites More sharing options...
Russ Posted 6June, 2014 Report Share Posted 6June, 2014 I wonder what 26 does - Switch for intensive cleaning? This could save me allot of time on the weekend. I think it's for the headlight washers but I don't have them so i'm not sure that blank you have below your mirror switch, I've been wondering what it does (I've got a rotary switch in there) Link to comment Share on other sites More sharing options...
Pauly Posted 6June, 2014 Report Share Posted 6June, 2014 I wonder what 26 does - Switch for intensive cleaning? This could save me allot of time on the weekend. That's what the mrs is for Link to comment Share on other sites More sharing options...
Mike D'Silva Posted 6June, 2014 Report Share Posted 6June, 2014 I wonder what 26 does - Switch for intensive cleaning? This could save me allot of time on the weekend. made me laugh... really needed it too! Link to comment Share on other sites More sharing options...
Dreamr Posted 6June, 2014 Report Share Posted 6June, 2014 I wish I had one of those mirror switches...... I have an electric drivers mirror, but the passengers has to be done manually.... Link to comment Share on other sites More sharing options...
SteveT Posted 6June, 2014 Author Report Share Posted 6June, 2014 I have all the right switchgear, just that nothing happens! Might be a fuse? Link to comment Share on other sites More sharing options...
Dreamr Posted 6June, 2014 Report Share Posted 6June, 2014 I'll happily give you a fuse if you give me the switchgear...... Link to comment Share on other sites More sharing options...
chrisheal Posted 6June, 2014 Report Share Posted 6June, 2014 Awesome ! thanks Russ, I've been trying to work out for 6 months now how to adjust the passenger mirror on my 964... Link to comment Share on other sites More sharing options...
tazzieman Posted 6June, 2014 Report Share Posted 6June, 2014 Awesome ! thanks Russ, I've been trying to work out for 6 months now how to adjust the passenger mirror on my 964... It's generally called a "passenger" Link to comment Share on other sites More sharing options...
Russ Posted 6June, 2014 Report Share Posted 6June, 2014 I have all the right switchgear, just that nothing happens! Might be a fuse? you also might not have electric mirrors. I'm pretty sure I have that switch but no motors inside my mirrors Link to comment Share on other sites More sharing options...
SteamWolf Posted 6June, 2014 Report Share Posted 6June, 2014 Reminds me of the goon show. "My grand father had one of those things whst makes the tea." " oh yes yes hmm what were they called. .." "My grandma" Link to comment Share on other sites More sharing options...
911oclock Posted 6June, 2014 Report Share Posted 6June, 2014 I wonder what 26 does - Switch for intensive cleaning? This could save me allot of time on the weekend. It uses a separate windshield washer tank located in the front boot, spoused to be filled with some special fluid. Link to comment Share on other sites More sharing options...
SteveT Posted 6June, 2014 Author Report Share Posted 6June, 2014 you also might not have electric mirrors. I'm pretty sure I have that switch but no motors inside my mirrors So what is the little joystick on the RH door for? It doesn't seem to adjust the RH mirror at all. Link to comment Share on other sites More sharing options...
Dreamr Posted 6June, 2014 Report Share Posted 6June, 2014 That joystick is the mirror adjustment.Could be like mine and be broken.... only the up works on mine.....Seems like I need the switch and a new joystick..Check and clean the fuse first as that might be the culprit.... Link to comment Share on other sites More sharing options...
Russ Posted 6June, 2014 Report Share Posted 6June, 2014 Yeah its the adjustment. Having seen the harness for each door there's a weight saving in not having it Link to comment Share on other sites More sharing options...
tazzieman Posted 6June, 2014 Report Share Posted 6June, 2014 That joystick is the mirror adjustment. Could be like mine and be broken.... only the up works on mine..... Seems like I need the switch and a new joystick.. Check and clean the fuse first as that might be the culprit.... Clean the switch contacts , after making sure it is actually connected. When people pull the door card to install speakers , it can be hard to plug back on properly. Link to comment Share on other sites More sharing options...
SteveT Posted 6June, 2014 Author Report Share Posted 6June, 2014 Interesting. This leads me to my next question. Where do the wires go that go to the door speakers and electric mirrors and windows? I have door speakers that don't work, I also have electric windows that do work but when I was trying to find the wires I couldn't find any into the doors for anything but they must be there somewhere for the windows to work. Link to comment Share on other sites More sharing options...
Russ Posted 7June, 2014 Report Share Posted 7June, 2014 I think they're behind the hinges, but I'm not sure. Might be worth checking the continuity on the speaker wires before you have to find them And when do we get to see your new car? Link to comment Share on other sites More sharing options...
Dreamr Posted 7June, 2014 Report Share Posted 7June, 2014 And when do we get to see your new car? Link to comment Share on other sites More sharing options...
