Pauly Posted 9September, 2014 Report Share Posted 9September, 2014 I was going to post a DIY for a strut brace, but as soon as i started making it, I came to realise that not everyone can make this at home and not everyone has access to stuff like a plasma cutter, band saw, welder, lathe and a mill. It may be easier mocking it up for a 911 as you have nothing in your way. I have obstacles to get around so it made it quite annoying. My objectives: It must work no matter how it looks Bar must be removable. Well this isn't the prettiest thing i've ever made. But here it is. Link to comment Share on other sites More sharing options...
Pauly Posted 9September, 2014 Author Report Share Posted 9September, 2014 Installed: It's a little tight near the fuel rail, i have some clear vinyl for it to rub on and see how it lasts. I need to redo the fuel anyway and i'll modify it if i have to. Link to comment Share on other sites More sharing options...
9fan Posted 9September, 2014 Report Share Posted 9September, 2014 Nice one Pauly, I have an S2 strut brace which will have to be modded to fit the 68,as you say tight fit. Link to comment Share on other sites More sharing options...
tk111 Posted 9September, 2014 Report Share Posted 9September, 2014 Well this isn't the prettiest thing i've ever made. But here it is. Looks pretty nice to me Pauly! I would love to see what you consider your best work. Link to comment Share on other sites More sharing options...
tazzieman Posted 9September, 2014 Report Share Posted 9September, 2014 What did people use before plasma cutters? "How much does it weigh?" "Is it billet alloy?" Link to comment Share on other sites More sharing options...
Tit Posted 9September, 2014 Report Share Posted 9September, 2014 Nice! Link to comment Share on other sites More sharing options...
Pauly Posted 9September, 2014 Author Report Share Posted 9September, 2014 Nice one Pauly, I have an S2 strut brace which will have to be modded to fit the 68,as you say tight fit. Thanks Mark, Very tight, I think most of them are bent to fit in Looks pretty nice to me Pauly! I would love to see what you consider your best work. Thanks mate, haha I made the catch can in the pictures (between the intercooler pipes) What did people use before plasma cutters? "How much does it weigh?" "Is it billet alloy?" Oxy? Weight? 2-3 kgs. It is mild steel. all of it. It's all i had laying around really. I do have aluminium laying around but to make the tube, i need to machine down a 80mm solid piece to 25mm. Waste of steel really. Nice! Thanks Link to comment Share on other sites More sharing options...
Uncle Posted 10September, 2014 Report Share Posted 10September, 2014 Good job if you ask me. DIY for the win. If I could give a little constructive crit it would be to make V2.0 adjustable so you can pretension the brace between the towers. This will help reduce flex on initial bite. Link to comment Share on other sites More sharing options...
Pauly Posted 10September, 2014 Author Report Share Posted 10September, 2014 Good job if you ask me. DIY for the win. If I could give a little constructive crit it would be to make V2.0 adjustable so you can pretension the brace between the towers. This will help reduce flex on initial bite. That was my original idea, But i didn't want to run around looking for those ball things with the adjusters on it (i forgot the name!) but i might split the middle and put one there. But then i need to find a reverse tap. At the moment it's really tight fit if you ask me. Link to comment Share on other sites More sharing options...
cyberpunky Posted 10September, 2014 Report Share Posted 10September, 2014 Nice work Pauly. I think on the Aussie delivered cars the AC lines can be an issue, as they are run next to the left tower. Link to comment Share on other sites More sharing options...
Pauly Posted 10September, 2014 Author Report Share Posted 10September, 2014 Nice work Pauly. I think on the Aussie delivered cars the AC lines can be an issue, as they are run next to the left tower. They where sort of in the way. Where are the US ones? I only just found out we have a clutch reservoir and the US don't Link to comment Share on other sites More sharing options...
T-Man Posted 10September, 2014 Report Share Posted 10September, 2014 Well done Pauly, nice work. Link to comment Share on other sites More sharing options...
Pauly Posted 10September, 2014 Author Report Share Posted 10September, 2014 Cheers Theo Link to comment Share on other sites More sharing options...
