Choppergrino Posted 30November, 2014 Report Share Posted 30November, 2014 Hi fellow Pcar friends, I need some advice on possible gearbox issues if anybody can help. I have a friend having trouble with his 915 gearbox which all of a sudden is having trouble going into 1st and reverse. Any thoughts ? Syncros? ..... Recommendations to fix in Melbourne. Thank you in advance Danny Link to comment Share on other sites More sharing options...
911oclock Posted 30November, 2014 Report Share Posted 30November, 2014 I'd be checking the coupler bushings first. Link to comment Share on other sites More sharing options...
Caledonian Posted 30November, 2014 Report Share Posted 30November, 2014 Ditto..... Link to comment Share on other sites More sharing options...
Choppergrino Posted 30November, 2014 Author Report Share Posted 30November, 2014 Thanks 911 o'clock is that something that can be done without a hoist? Is there any how to on doing the checks. Thanks Danny Link to comment Share on other sites More sharing options...
Russ Posted 30November, 2014 Report Share Posted 30November, 2014 http://www.pelicanparts.com/techarticles/101_Projects_Porsche_911/37-Shifting_Improvements/37-Shifting_Improvements.htm Link to comment Share on other sites More sharing options...
Harvs11 Posted 30November, 2014 Report Share Posted 30November, 2014 Thanks 911 o'clock is that something that can be done without a hoist? Is there any how to on doing the checks. Thanks Danny Hi Danny, easiest check is to open the access plate in the tunnel between the frt & rr seats. The coupling should be tight. If it slops around when the shift lever is moved side to side it will not find the gears properly. Usually worn or collapsed bushings are the problem. I posted a basic "how to" on this a couple of weeks back. Good luck. edit: Link to comment Share on other sites More sharing options...
Choppergrino Posted 30November, 2014 Author Report Share Posted 30November, 2014 Thank you everybody for your help !!!! Link to comment Share on other sites More sharing options...
Peter M Posted 30November, 2014 Report Share Posted 30November, 2014 I'd really suggest you check that the clutch is operating correctly first and foremost. (The usual giveaway is if the clutch is dragging due to the common cause of excess freeplay he will probably notice a grunch trying to select reverse.)If it's the coupler he will likely be having trouble selecting other gears as well as 1st and reverse. I'd suggest he first check the tightness of the bolt and grubscrew on the each end of the coupler before launching into a remove and rebuild. Link to comment Share on other sites More sharing options...
Choppergrino Posted 1December, 2014 Author Report Share Posted 1December, 2014 Thanks Peter great advice also Link to comment Share on other sites More sharing options...
Zelrik911 Posted 12December, 2014 Report Share Posted 12December, 2014 Thank you everybody for your help !!!! What was causing the problem with g/change? Was it an easy fix? Link to comment Share on other sites More sharing options...
Choppergrino Posted 12December, 2014 Author Report Share Posted 12December, 2014 It ended up being a simple fix, checked the linkage that was like new, then checked the cable on gearbox. The cable had about 12mm of free play , once I tightened that it was like a new Link to comment Share on other sites More sharing options...
Coastr Posted 13December, 2014 Report Share Posted 13December, 2014 It ended up being a simple fix, checked the linkage that was like new, then checked the cable on gearbox. The cable had about 12mm of free play , once I tightened that it was like a new Thanks for all the tips guys and car is driving heaps better ! Which cable? The clutch cable? Link to comment Share on other sites More sharing options...
Choppergrino Posted 13December, 2014 Author Report Share Posted 13December, 2014 Which cable? The clutch cable? Yes correct ! It was the clutch cable, just tightened the 2 lock nuts up a bit more. Link to comment Share on other sites More sharing options...
911oclock Posted 13December, 2014 Report Share Posted 13December, 2014 You may need to redo the cable adjustment at the trans. It's a bit of a process but easy to do. Link to comment Share on other sites More sharing options...
Choppergrino Posted 28December, 2014 Author Report Share Posted 28December, 2014 Just Replaced clutch cable , a lot better now Link to comment Share on other sites More sharing options...
