firstone Posted 11August, 2015 Report Share Posted 11August, 2015 Thanks. Link to comment Share on other sites More sharing options...
firstone Posted 11August, 2015 Report Share Posted 11August, 2015 I'm out too Ken. Link to comment Share on other sites More sharing options...
Mike D'Silva Posted 12August, 2015 Report Share Posted 12August, 2015 bugger.. checked the garage yesterday, and my celing is just too bloody low. Also, my garage door mechanism would hit the roof of the car.I'm stuck with shitty jackstands. Link to comment Share on other sites More sharing options...
twood Posted 13August, 2015 Author Report Share Posted 13August, 2015 bugger.. checked the garage yesterday, and my celing is just too bloody low. Also, my garage door mechanism would hit the roof of the car.I'm stuck with shitty jackstands. Sell the house? Link to comment Share on other sites More sharing options...
BlitzKonig Posted 14August, 2015 Report Share Posted 14August, 2015 Hey Ken, Im interested. Ill check the shed tonight, but I believe it should fit. Do you have any information regarding the concrete slab thickness? I looked online and they simply show the process on installing the bolts, but not what would be considered "properly installed". Link to comment Share on other sites More sharing options...
twood Posted 14August, 2015 Author Report Share Posted 14August, 2015 In the installation instructions it simply says "+A solid level concrete floor with no more than 3 degrees of slope". I never had any issues with the unit moving.Hey Ken, Im interested. Ill check the shed tonight, but I believe it should fit. Do you have any information regarding the concrete slab thickness? I looked online and they simply show the process on installing the bolts, but not what would be considered "properly installed".Where are you located ? - freight has been the biggest issue to dateThere is more information on the Maxjax site:Anchor Bolt Stress AnalysisJust how strong are the anchor bolts used for the MaxJax™? Here, we'll tell you exactly. In an effort to show just how safe the anchor bolts are when properly installed, our engineers performed stress analysis tests on just the three back anchors. Although we recommend using all five anchor bolts, we wanted to make sure there was no chance of failure when properly installed in concrete.Analysis: Base plate anchor bolts (3 on outside edge) in tension. Analysis was performed using published Allowable Stress Design (ASD) "Design of Base Plates"......"Moments of Large Effective Eccentricities" formulas and procedures.Formulas:fp = 0.7 x fce = M/Pf1 = fp x B x N1 / 2A = f1+/-(f12 - (.667 x fp x x (PA1+M)).5 / (fpxB/3)T = (fp x A x B / 2) - PT per bolt = T / # boltsSafety Factor = Ultimate Bolt Strength / T per BoltDesign Factors:Fc = 3000psi (Strength of concrete)# bolts in tension = 3Anchor Bolt Ultimate Strength = 12,580 lbs. PD58, 5/8" Wej-It Drop in Anchor, installed in 3000psi concrete per manufacturer's instructions.Compressive Load = 3383 lbs. (3000 lbs. lifting + 383 lbs. lift assembly weight)Moment = 124598 in-lb (per ALI B-4 lift diagram arm extension at rated load)Moment = 138549 in-lb (with fully extended arms) Results:Tension stress per bolt = 2,838 lb tension, loaded per ALI B-1 diagram.Tension stress per bolt = 3,238 lb tension, loaded per Arms Fully Extended.Safety Factor = 443% (based on ALI B-1 arm extension)Safety Factor = 389% (based on fully extended arms perpendicular to the lift) Link to comment Share on other sites More sharing options...
Russ Posted 14August, 2015 Report Share Posted 14August, 2015 i doubt your slab would be thin enough for it to be a problem, i assume your shed is bolted to it as well? Link to comment Share on other sites More sharing options...
twood Posted 14August, 2015 Author Report Share Posted 14August, 2015 i doubt your slab would be thin enough for it to be a problem, i assume your shed is bolted to it as well?Russ should know- i think part of his work is about fixing stuff to concrete slabs Link to comment Share on other sites More sharing options...
michel Posted 15August, 2015 Report Share Posted 15August, 2015 Base plate sizing plays a role. In some instances min slab thickness 100mm don't cut the mustard. If you can't find info from manufacturer have a quick chat with a structural engineer - must be one or two here Link to comment Share on other sites More sharing options...
BlitzKonig Posted 16August, 2015 Report Share Posted 16August, 2015 Yeah I need to cut out and go deeper to support this frame. Will need to do some more investigating. Guess thats me out as well Link to comment Share on other sites More sharing options...
IAM_911 Posted 17August, 2015 Report Share Posted 17August, 2015 Because I have made the decision to sell my 964 C2 there is no reason to hold onto the Maxjax hoist.It retails in Australia for $3300 so I am looking for $2250. I will list it on Ebay or Gumtree in the next days but thought I would give the PFA members first option.More information about the hoist can be found herehttp://www.maxjaxusa.com/The hoist is located in Brisbane and can easily be moved in a box trailer/where is the dislike button? Link to comment Share on other sites More sharing options...
twood Posted 17August, 2015 Author Report Share Posted 17August, 2015 where is the dislike button?What have I done wrong to dislike? Link to comment Share on other sites More sharing options...
Mike D'Silva Posted 18August, 2015 Report Share Posted 18August, 2015 Might be "disliking" that you are selling all your gear and your car... Link to comment Share on other sites More sharing options...
IAM_911 Posted 19August, 2015 Report Share Posted 19August, 2015 yesBecause I have made the decision to sell my 964 C2 there is no reason to hold onto the Maxjax hoist.It retails in Australia for $3300 so I am looking for $2250. I will list it on Ebay or Gumtree in the next days but thought I would give the PFA members first option.More information about the hoist can be found herehttp://www.maxjaxusa.com/The hoist is located in Brisbane and can easily be moved in a box trailer/where is the dislike button?Yes thats it.I thought once a Porsche man is always a Porsche for man ever.I would keep the hoist in case the Porsche bog over powers your rational side again. Link to comment Share on other sites More sharing options...
Mike D'Silva Posted 20August, 2015 Report Share Posted 20August, 2015 I saw Ken driving his car today... looked and sounded good.. (the car I mean.. sorry Ken) Link to comment Share on other sites More sharing options...
clutch-monkey Posted 22August, 2015 Report Share Posted 22August, 2015 Yeah I need to cut out and go deeper to support this frame. Will need to do some more investigating. Guess thats me out as well ferd's you reckon it would fit my shed..? Link to comment Share on other sites More sharing options...
twood Posted 23August, 2015 Author Report Share Posted 23August, 2015 If you want to check out the lift in person give a call and i am happy to explain the installation and working etc Link to comment Share on other sites More sharing options...
twood Posted 27August, 2015 Author Report Share Posted 27August, 2015 The MaxJax 2 post hoist sold yesterday. Thank you to those that inquired and also to the people that gave the post a free bump. cheers Ken Link to comment Share on other sites More sharing options...
