twood Posted 10August, 2015 Report Posted 10August, 2015 Because I have made the decision to sell my 964 C2 there is no reason to hold onto the Maxjax hoist.It retails in Australia for $3300 so I am looking for $2250. I will list it on Ebay or Gumtree in the next days but thought I would give the PFA members first option.More information about the hoist can be found herehttp://www.maxjaxusa.com/The hoist is located in Brisbane and can easily be moved in a box trailer/
twood Posted 10August, 2015 Author Report Posted 10August, 2015 9er was in first and I suggested he check the freight first. You are in Canberra and I would also suggest check the freight cost. It does not really need much packing as it is fairly robust unit but my price does not include freight or any requested packing.It is a great unit for a domestic garage and I could not have done my engine rebuild with out it and other than the rebuild and a few tech days it's not had a lot of use.
twood Posted 10August, 2015 Author Report Posted 10August, 2015 One day it will be mine.Oh yes. One day..If Michel buys it then it's a bit like a swimming pool-the best one to have is the neighbors. Maybe do a deal with Michel on the freight cost?
Tit Posted 10August, 2015 Report Posted 10August, 2015 If Michel buys it then it's a bit like a swimming pool-the best one to have is the neighbors. Maybe do a deal with Michel on the freight cost? lol. You should ask TK111 and michel about the kollectiv 'communal' tools
michel Posted 10August, 2015 Report Posted 10August, 2015 lol. You should ask TK111 and michel about the kollectiv 'communal' tools or Stavro Twood how much does this baby weigh?
twood Posted 10August, 2015 Author Report Posted 10August, 2015 or Stavro Twood how much does this baby weigh?Michel For you and anyone else that may be interested ose to two years meticulously getting the most strength out of each measurement. No corners were cut in the making of this product.Lifting Capacity*: 6,000 Lbs. / 2727 Kg. *Max Capacity / Front Axle: 3,000 Lbs. / 1364 Kg. *Max Capacity / Rear Axle: 3,000 Lbs. / 1364 Kg.Max Load per Arm: 1,500 Lbs. / 682 Kg.A - Height Overall: (*) 89" / 2261 mm.B - Height of Column: 64" / 1626 mm.C - Width (Outside of Base Plate): 105" - 125" / 2667 mm. - 3175 mm.D - Arm Reach (Min.): 24" / 610 mm.E - Arm Reach (Max.): 44" / 1117.5 mm.F - Min. Pad Height: 3.5" / 89 mm.G - Max Lift Height (Pad only): 45" / 1143 mm.H - Max Lift Height (With 3" Adapter): 48" / 1219 mm.Motor: (**) 110-220 VAC / 50-60 Hz. 1Ph.Length of Hose(s): 156" / 3962 mm.Time of full Rise: 30-SecondsIndividual Column Weight: 300 Lbs. / 136 Kg.Shipping Weight: 880 Lbs. / 399 Kg.Shipping Dimensions: 14" x 64" x 40" / 356 mm. x 1626 mm. x 1016 mm.
LeeM Posted 10August, 2015 Report Posted 10August, 2015 At least i know where i'll be going for any underneath work if Chris buys it! Thanks in advance Chris I'd love it, but my shed is a joke, and not level, and I don't really need it etc etc
tk111 Posted 10August, 2015 Report Posted 10August, 2015 ill buy it thanks MichelMichel,It will work great in my shed, next to the corner weights
michel Posted 10August, 2015 Report Posted 10August, 2015 Michel,It will work great in my shed, next to the corner weights Stavro drop them off TK?
tk111 Posted 10August, 2015 Report Posted 10August, 2015 Stavro drop them off TK?when you bring the joist, I will call Stavro to bring the scales
michel Posted 10August, 2015 Report Posted 10August, 2015 when you bring the joist, I will call Stavro to bring the scalesyou want softwood or hardwood? I've still got some spotted gum that I had milled in Braidwood, left over from rebuilding the verandah. Furniture grade
Russ Posted 10August, 2015 Report Posted 10August, 2015 having used this hoist on a few occasions i can endorse this product and/or service
twood Posted 11August, 2015 Author Report Posted 11August, 2015 is it sold? im just up the road....Michel has said he wants it and i am guessing he is checking freight costs but I have heard no more from yesterday.are you interested?
michel Posted 11August, 2015 Report Posted 11August, 2015 howdy im interested just waiting on a freight quote
twood Posted 11August, 2015 Author Report Posted 11August, 2015 howdy im interested just waiting on a freight quoteThat's fine - you were in first
twood Posted 11August, 2015 Author Report Posted 11August, 2015 hi kenim out - nextThanks Michel for letting me know-Mike you are next in line if interested otherwise I will run it on other sites
Mike D'Silva Posted 11August, 2015 Report Posted 11August, 2015 Ken, from memory, the lift has that steel pin that locks at the top. With your car on there, and that pin engaged, how high (approx) is the roof of the car from the floor?You havent seen my garage, but Im almost certain its shorter than yours....
twood Posted 11August, 2015 Author Report Posted 11August, 2015 Ken, from memory, the lift has that steel pin that locks at the top. With your car on there, and that pin engaged, how high (approx) is the roof of the car from the floor?You havent seen my garage, but Im almost certain its shorter than yours.... Mike have a look at the diagram above - I estimate that my car goes up to 2200mm from (floor to roof top)- the ram appears to go a little higher at 2261mm (7 foot 5 inches)
twood Posted 11August, 2015 Author Report Posted 11August, 2015 Hey Ken. I'm in if mike doesn't buy it.I will wait to here back from Mike and I will let you know
