kiwi911 Posted 4September, 2015 Report Posted 4September, 2015 Hi Guys,Looking for alternative front disks for a 996 GT3 that spends half it's life on the track?What does everyone use?Also - what pads to you use, I want a pad that doesn't queel and not too harsh......Your advice would be appreciated.CheersPaul
spiller Posted 4September, 2015 Report Posted 4September, 2015 I'm using Brembo Motorsport Type 3 two peice rotors front and rear, supposedly last 3-4 times longer than the OEM stuff but $$$ on the initial buy in. Replacement rings are about the same as OEM. Pads not sure at the moment, assume pagid of some description. Will be putting performance friction 08 in there when they're done and probably 01 in the rear to get the rears to do some work.other good option for discs is performance friction two piece.
1q2w3e4r Posted 4September, 2015 Report Posted 4September, 2015 I use Pagid Yellow RS29s in my 6TT and they are fantastic.
James P Posted 5September, 2015 Report Posted 5September, 2015 I use Pagid RS29s with OEM rotors front & OEM pads & rotors rear in my 997 GT3I also run Castrol SRF brake fluid this is most important
kiwi911 Posted 6September, 2015 Author Report Posted 6September, 2015 Guys - do the Pagid RS29s squeel like a piglet under normal road use??
1q2w3e4r Posted 6September, 2015 Report Posted 6September, 2015 Not really, but you can't have the best of both worlds.
Blue964 Posted 7September, 2015 Report Posted 7September, 2015 Just had the Brembo Motorsport type 3 fitted to my gt3 based on a recommendation from pr tech...but unfortunately very expensive. embarrassingly my gt3 spends little time on a track so i have absolutely no idea what their life will be like. but the guys a pr tech are very good when it comes to setting up p-cars for track so reckon you should give them consideration.
Skidmarks Posted 19January, 2016 Report Posted 19January, 2016 I use Performance Friction rotors front and rear. 06 and 01 Performance Friction pads or Project Mu. the Project Mu's are a bit harsh but great feel cold.I've used this combination for the last 10 years on GT3's and well as Cup Cars. Rotor life is good and pricing is very good when compared to the Brembo product which I also used a lot until I went to PF.Their service is great too.
spiller Posted 19January, 2016 Report Posted 19January, 2016 I use Performance Friction rotors front and rear. 06 and 01 Performance Friction pads or Project Mu. the Project Mu's are a bit harsh but great feel cold.I've used this combination for the last 10 years on GT3's and well as Cup Cars. Rotor life is good and pricing is very good when compared to the Brembo product which I also used a lot until I went to PF.Their service is great too.Where do you source your PFC rotors from if you don't mine me asking? My last set of brembos cost $1800 just for the replacement rings which was about the same price as the whole PFC rotor and hat combo.
Skidmarks Posted 19January, 2016 Report Posted 19January, 2016 Where do you source your PFC rotors from if you don't mine me asking? My last set of brembos cost $1800 just for the replacement rings which was about the same price as the whole PFC rotor and hat combo. I go direct. They ship as well.
DJM Posted 19January, 2016 Report Posted 19January, 2016 My car is mostly road driven but I've done 3 track days. PO had fitted brembo Motorsport discs and project Mu pads. When front pads were getting low, I did some asking around and 2 Porsche workshops independently recommended Circo pads. I thought they might be a bit aggressive as they quote for Motorsport use, took the punt and had a set fitted front only just before Sandown and they were great. No fade, pulled up well, no squeal, don't generate lots of dust Also very good on road, very limited squeal. Well priced too (can't recall exactly)http://circobrakes.com/?page_id=38
