911 Snake Posted 17March, 2016 Report Share Posted 17March, 2016 Hi all, Firstly I did a search on the forum, rennlist and 911uk but no specific details to my question. I have 997.1 Carerra with PSE. I have the exhaust button to open and close the baffles and currently have the plug disconnected in the engine bay so its open all the time. Great noise, but I would like it a little louder and throatier So, what are some exhaust (sections) upgrades that I could consider that will still work in conjunction with my PSE? - I believe the baffles are located in the big mufflers behind the rear wheels so I wouldn't be changing them. Doing a search I was considering the following which (I THINK) will give me a louder note but not effect the functionality of the PSE unit? http://www.cargraphicts.com/index.php?id=120303&L=1 - 11th, 12th and 13th options from cargraphic 11th Sport Catalytic Converter Set "X" - Pipe VersionOBD2 compliant with 200Cell Catalytic Converters No ECU programming required and no CEL 12th Catalytic Converter Replacement Pipe Set Crossover VersionWithout Catalytic Converters Assuming this is definitely illegal without cats? 13th Catalytic Converter Replacement Pipe Set "X" - Pipe Version"X"-pipe version without catalytic converters Assuming this is definitely illegal without cats? Appreciate if anyone has any other suggestions or alternatives? I'm purely going for sound and a relativity cheap option. much appreciated! Link to comment Share on other sites More sharing options...
Macca Posted 18March, 2016 Report Share Posted 18March, 2016 Going catless is illegal in VIC and you can smell a catless car. I am assuming Police wouldn't distinguish that smell so should be right in that regard but you may have hwy drone or far too excessive noise. Would go the 200 cell cats if i was doing that modification. Link to comment Share on other sites More sharing options...
911 Snake Posted 18March, 2016 Author Report Share Posted 18March, 2016 Thanks Macca,I figured catless was completely illegal and assuming it applies to all other states as well. That narrows the three options to one then. Cheers.I certainly want to keep all things above board and legal (excluding the decibels of which I can push the quiet button when needed ). If anyone else has any other suggestions I'd love to know.Thanks all. Link to comment Share on other sites More sharing options...
Macca Posted 18March, 2016 Report Share Posted 18March, 2016 your welcome,Bypass pipes if you really want loud. (don't think the sound would be enjoyable at low rpms)http://www.fabspeed.com/porsche-997-carrera-muffler-bypass-pipes/ Link to comment Share on other sites More sharing options...
teknostar Posted 19March, 2016 Report Share Posted 19March, 2016 I have some used AWE sports cats for salehttp://www.awe-tuning.com/awe-997sexhaust$1500 and they are yours, pick up Hawthorn, VICThey will bolt up to the stock muffler sections and will add a much more throaty sound + a chunk of TQ Link to comment Share on other sites More sharing options...
dan_189 Posted 20March, 2016 Report Share Posted 20March, 2016 Bit of a hack mod but you can also modify your air intake so the resonance/Helmholtz chamber stays closed giving a louder intake noise too it also modifies the exhaust sound (or it did on my 996).As for cats, highly recommend cargraphic, 200 CEL cats seem to be the way to go and give the best all round performance Link to comment Share on other sites More sharing options...
911 Snake Posted 20March, 2016 Author Report Share Posted 20March, 2016 Apologies for the lack of reply over the weekend. Thanks for everyone's feedback!WOW! Macca those bypass pipes are LOUD! love it - does it require a ECU re-program and does it throw a CEL light?More research to do but I think I'll lean towards some new cats when It goes in for its service later this year. Weltmeister supply Cargraphic exhausts so I'll 'sound' them out(pun intended)Thanks allI have some used AWE sports cats for salehttp://www.awe-tuning.com/awe-997sexhaust$1500 and they are yours, pick up Hawthorn, VICThey will bolt up to the stock muffler sections and will add a much more throaty sound + a chunk of TQCheers Teknostar, at this stage I'm just weighing up all options but thanks for the offer and will PM if interested down the track Link to comment Share on other sites More sharing options...
Macca Posted 20March, 2016 Report Share Posted 20March, 2016 Bypass pipes are removing the mufflers - agreed - they sound mean (on the videos) but for everyday driving it be too much IMO. It wouldn't throw a cel as the o2 sensors are pre exhaust (on the cats) and the claims of higher HP maybe ECU flash is needed - Fabspeed a pretty reputable (exhaust work) but I would imagine with bypass pipes the quality of the engine note would be lost and that hollow (no muffler sound) would be more apparent than the high revving note. Unless its a track car - I would go the 200 cell cats / and or full exhaust set up. Link to comment Share on other sites More sharing options...
Raven Posted 21March, 2016 Report Share Posted 21March, 2016 Gundo Hack and 200 cell cats...................... Link to comment Share on other sites More sharing options...
dan_189 Posted 21March, 2016 Report Share Posted 21March, 2016 Or full cargraphic system and get the weight saving as well Link to comment Share on other sites More sharing options...
Daz987 Posted 12April, 2016 Report Share Posted 12April, 2016 your welcome,Bypass pipes if you really want loud. (don't think the sound would be enjoyable at low rpms)http://www.fabspeed.com/porsche-997-carrera-muffler-bypass-pipes/ This sounds nuts! Turns your 996 into a fire breathing monster - sounds so similar to my old 930 [without the turbo whistle]. Wow - how has it been working for you?? I'm seriously interested after hearing your car in the movie!! Link to comment Share on other sites More sharing options...
Macca Posted 12April, 2016 Report Share Posted 12April, 2016 This sounds nuts! Turns your 996 into a fire breathing monster - sounds so similar to my old 930 [without the turbo whistle]. Wow - how has it been working for you?? I'm seriously interested after hearing your car in the movie!! Sorry , its not my car - I just linked a video of the bypass pipes from the fabspeed site ,coincidentally it happens to be a NSW plate so maybe someone here may know him etc. (I have gundo hack) Link to comment Share on other sites More sharing options...
Daz987 Posted 13April, 2016 Report Share Posted 13April, 2016 Yeah, I saw you were from Melbourne, just thought you had relocated. No worries at all. Link to comment Share on other sites More sharing options...
