D-banger Posted 23April, 2016 Report Share Posted 23April, 2016 Some of you may have noticed I have had some Fuchs wheels comings and goings recently.Anyway I had some Potenza RE003 fitted recently. Took the P car down to the mechanic for some lowering and an alignment. Mechanic sees yellow paint dot markings and says they should be aligned with the valve stem.i understand the yellow paint dot marks the lightest balance point of the tyre and this should be aligned with the wheel valve stem (the heaviest point of the wheel).I took the wheels back to the tyre go who says the yellow dot alignment is old school and not necessary now with current wheel balance equipment. I asked if the would refit and rebalance the wheels. Wheels guy says the rears have minimal balance weights fitted and it would be a waste of time, but he said he would redo the fronts which had more balance weights fitted (60 gm, but within spec of 80 gm). $30 per wheel.I picked the wheels up and the yellow paint markings were a lot closer to the valve stem and it appeared that less balance weights were required. To their credit wheel guy waived $30 charges.Side note: wheel guy says more balance weights are required when applied to the inside of the wheel, as compared to being placed on the outer rim.Opinions sort: do people worry about paint dot markings when they have tyres fitted?I am sure @Peter M and @carl888 will chime in. Link to comment Share on other sites More sharing options...
OZ930 Posted 24April, 2016 Report Share Posted 24April, 2016 Link to comment Share on other sites More sharing options...
OZ930 Posted 24April, 2016 Report Share Posted 24April, 2016 This is interesting reading toohttp://www.tirebusiness.com/article/20070813/ISSUE/308139967/are-you-seeing-dots-those-color-coded-sidewall-markings-serve-a Link to comment Share on other sites More sharing options...
Peter M Posted 24April, 2016 Report Share Posted 24April, 2016 Doug,I've never had cause for concern. Lucky? Maybe not, I think that may reflect on the good manufacturing tolerances of name brand tyres which I am always happy to pay for and they do usually mount the yellow dot within shouting distance of the valve stem.I'd only be concerned if there are either no weights (For some reason if you say the tyres are for your trailer they often won't bother balancing without being asked which pisses me off) or if there is a excess amount of weights which would indicate a poor quality tyre, such as one with a internal vulcanised patch repair.Red dots? Way out of my league and learnt more today from Brian's link than I ever knew!My only concern is the move away from lead to plated steel because they have to be bigger and eventually look unsightly! Link to comment Share on other sites More sharing options...
LeeM Posted 24April, 2016 Report Share Posted 24April, 2016 I'm sorry, what? $30 to balance a wheel? Jeebus Link to comment Share on other sites More sharing options...
firstone Posted 24April, 2016 Report Share Posted 24April, 2016 Break it down.Position vehicle over liftPosition lift blocksLift vehicleChoose ratchet gunChoose correct socketPlace socket on gunPlace socket securely over wheel nutRemove wheel nutsRemove wheelPlace wheel on bead breakerSecure wheel to bead breakerPosition breaker arm the correct distance from rim............???? Link to comment Share on other sites More sharing options...
OZ930 Posted 24April, 2016 Report Share Posted 24April, 2016 Break it down.Position vehicle over liftPosition lift blocksLift vehicleChoose ratchet gunChoose correct socketPlace socket on gunPlace socket securely over wheel nutRemove wheel nutsRemove wheelPlace wheel on bead breakerSecure wheel to bead breakerPosition breaker arm the correct distance from rim............???? Rattle gun !!! Link to comment Share on other sites More sharing options...
D-banger Posted 24April, 2016 Author Report Share Posted 24April, 2016 I'm sorry, what? $30 to balance a wheel? JeebusBreak it down.Position vehicle over liftPosition lift blocksLift vehicleChoose ratchet gunChoose correct socketPlace socket on gunPlace socket securely over wheel nutRemove wheel nutsRemove wheelPlace wheel on bead breakerSecure wheel to bead breakerPosition breaker arm the correct distance from rim............???? The wheels had already been removed from the car, so all they had to do we're the last 3 steps. Link to comment Share on other sites More sharing options...
LeeM Posted 24April, 2016 Report Share Posted 24April, 2016 The wheels had already been removed from the car, so all they had to do we're the last 3 steps. Good ol Ptax! That's why I always ask how much it is over the phone, and say its an old Volksy.Some may recall I had removed the 2 front disc rotors machined for the 912 at $40each. Asked over the phone coupla weeks later about my rear rotors saying they were off of a Porsche, '$400 mate. Because we have to retool the jig' Yeah right mate Link to comment Share on other sites More sharing options...
tazzieman Posted 24April, 2016 Report Share Posted 24April, 2016 Machining rotors is the cash cow for brake places. In many instances it's not required. But the gen.pub. wouldn't question the "need". Link to comment Share on other sites More sharing options...
