symsy Posted 17June, 2016 Report Share Posted 17June, 2016 Tell me … whats the lowest trolley jack you have come across , I wanna get under the TT , I bought a jack its say 70mm but had t return it as it was actually 92.5mm… dem dere boxes lie you know Any experiences with getting a ultra low profile 2t jack or maybe 1.5 under your car and where did ya source it ??Im tired of getting the little biddy alu porsche one out to start the journey.. Link to comment Share on other sites More sharing options...
Peter M Posted 17June, 2016 Report Share Posted 17June, 2016 Symsy,I found that having 4 planks about 1 and 1/2 inches thick to drive the car up and onto makes the whole jacking up exercise much easier and the height of the actual jack less critical. Just cut a bit of a ramp or taper on one end of each plank to make the run up easier. Each plank is about 4 feet long as the car will move a bit towards the jack as it is raised.Hope this helps. Link to comment Share on other sites More sharing options...
symsy Posted 17June, 2016 Author Report Share Posted 17June, 2016 I reckon you should patent that idea… Porsche IplankI like that lateral thinking Link to comment Share on other sites More sharing options...
tazzieman Posted 17June, 2016 Report Share Posted 17June, 2016 I reckon you should patent that idea… Porsche IplankI like that lateral thinking Or .... Basil Fawlty: Next contestant, Mrs. Sybil Fawlty from Torquay. Specialist subject - the bleeding obvious. Link to comment Share on other sites More sharing options...
tazzieman Posted 17June, 2016 Report Share Posted 17June, 2016 Gotne chunky mates Symsy? Link to comment Share on other sites More sharing options...
ANF Posted 17June, 2016 Report Share Posted 17June, 2016 What @Peter M said, did this on my E Class cause it was so low Link to comment Share on other sites More sharing options...
Harvs11 Posted 17June, 2016 Report Share Posted 17June, 2016 Tell me … whats the lowest trolley jack you have come across , I wanna get under the TT , I bought a jack its say 70mm but had t return it as it was actually 92.5mm… dem dere boxes lie you know Any experiences with getting a ultra low profile 2t jack or maybe 1.5 under your car and where did ya source it ??Im tired of getting the little biddy alu porsche one out to start the journey.. How low us your TT? I thought my car was low but I get the Arcan 1500 Jack under with plenty to spare Link to comment Share on other sites More sharing options...
Peter M Posted 17June, 2016 Report Share Posted 17June, 2016 Harvswhile we are sharing our garage secrets, what do you put between the jack lifting pad and your car? Link to comment Share on other sites More sharing options...
Harvs11 Posted 17June, 2016 Report Share Posted 17June, 2016 The jack pad has a rubber insert but I also put a piece of 10mm rubber on to protect the body/engine when lifting from the front or back. I've got an insert to go into the bodyside lifting socket. Link to comment Share on other sites More sharing options...
Mike D'Silva Posted 19June, 2016 Report Share Posted 19June, 2016 I use one of these on my 964.. no issues...https://www.tradetools.com/product-range/machinery-and-workshop/garage-equipment/hydraulic-tools/renegade-3000kg-garage-jack-trolley-quick-lift-low-profile Link to comment Share on other sites More sharing options...
P-Kay Posted 19June, 2016 Report Share Posted 19June, 2016 For the SC, I use one of these --> http://www.ebay.com/itm/Porsche-356-911-912-914-Jack-Pad-Extension-For-Hydraulic-Floor-Jack-NEW-/151057989067For the 996, I go the plank o' wood method Link to comment Share on other sites More sharing options...
symsy Posted 20June, 2016 Author Report Share Posted 20June, 2016 Hmmm double pumpers So where you guys jacking from at the rear …the TT the jack goes under , tried an Arcan but not enough reach for anywhere I would like to jack against.Big subject this … Is it safe to say Green Targa .. down here in the bowels of PFA Link to comment Share on other sites More sharing options...
P-Kay Posted 20June, 2016 Report Share Posted 20June, 2016 I use a block of wood and jack from the centre of the case to get that extra lift.You can get fancy and purchase one of those engine jack point/tow hook/skid contraption. Not sure whether it is for all 911s though http://www.ebay.com.au/itm/JACK-STAND-SCREWED-PORSCHE911-CAR-LIFT-SUPPORT-AT-REAR-ENGINE-/151384075228?hash=item233f31abdc:g:mMgAAOSwGvhT7LUfNo good for 'no provenance' lime green coloured cars though Link to comment Share on other sites More sharing options...
