An odd question
Guest vas930
Guest vas930
As the off porsche topic of the forum, I thought I would seek the wisdom of the forum.
For some time now I have been a tad freaked out by this question.
I have asked others with no clear answer.
Here goes.
If you removed your right eye from its socket and leaving the wires all hooked up.
You then held it just in front of the left eye( 5 or 10mm) facing each other.
Looking directly at each other.
What yould you see ?
How would the brain cope with this? :unsure:
Not sure how the hell I even thought about it, but it just wont go away.
Any ideas?
I don't have the answer to your question...........but I am starting to worry about you!
There is a way you could simulate this with mirrors. Reflecting the image from one eye to the other using a couple of mirrors at 45 degrees to the eyes and each other.
May need a convex type to magnify the images.
I expect you to have an answer by Monday. :D
Vas, yellow pages quick - p for psychiatrists!! Go polish your Turbo or head to the newsagent for Porsche magazines. OR go back to work.(Alternately, its the lack of sunshine).
Cheers
Paul M ( also bored)
im sure you would see a very handsome man staring back at you Vas.!!
That would be a "very handsome one eyed man staring back at you."
Sounds a bit like a country and western song
Guest vas930
Hey, thanks for all the kind words, gents. :D
However, this does nothing to get this off my mind.
I like the mirror idea, but not sure it would be the same as the the eye removal.
Any eye/brain docs out there ?
A quick test in your next surgery would be greatly appreciated.
Dont make me try a 6000rpm launch in reverse.
Anyone ?
Here goes.
Any ideas?
Hey Vas , you should know by now that its dangerous to pick your own mushrooms
Guest vas930
Be like looking into 2 mirrors facing each other, the image will repeat until to get to π (Pi) or .
Sheesh.
Are you sure :wacko:
Hi Vas,
Can't tell 'cos I can't see that far. <_<
At every reflection the image just gets smaller until it disappears up yr a**e.
OK here is another weird question.
Compress and clamp a big coil spring. Dunk the clamped spring in acid, leave until the spring dissolves.
Where has the energy used to compress the spring gone?
This is getting ridiculous..
Guest vas930
" This is getting ridiculous" :D
I see your point with the spring question.
With quantum theory many questions come up that are hard to understand.
Look at Schrödinger's cat, hard to understand but makes sense.
This eye thing has me stumped.
Cant see any way of finding out without a test (not doing test)
I think I will leave it at that.
Good reading, http://whatis.techtarget.com/definition/Schrodingers-cat
Guest vas930
EYE UPDATE !
Seems after some more research, the wires to the eye cant stretch far enough to find out.
This means both eyes will need to come out in order to face each other and get an answer.
Not sure if this makes me feel any better.
No !
Still thinking about it.
And the mental image is far worse. :wacko:
  • 3 weeks later...
Guest Nick987
Hey Vas, I'm pretty sure unless you are a T2000 model, you have an optic nerve instead of 'wires' and I am guessing that is what you are referring to.
Also, simply cover one eye and go stare at the other in a mirror up close, that is pretty much what you would see. Then try with both eyes up close at the mirror. You will see an eyeball/s, albeit a very gory and bloody one/s, and probably drying out as it won't be able to blink any more, staring back.
Your brain won't seize or short from the infinite loop...unless you are a T2000 model and aren't up to date with your service packs...
Guest Nick987
You have no idea how weird it can get!
Yeah, just look at what happened yesterday with all the porka action...Man that got intense...
Easy way to find out...try and join up on the photobucket site that will soon let you know what model you are. are. are.. are.
  • 1 month later...
