reggiegums Posted 12August, 2020 Report Share Posted 12August, 2020 Porsche 914-6 engine for sale. 2.0 liter. Removed years ago from a running car to swap for 3.0 liter. Looking for $8,000 ONO. Disassembled and almost complete. Located in Perth. Will ship. PM for details. Oldskl60 1 Quote Link to comment Share on other sites More sharing options...
9er Posted 14August, 2020 Report Share Posted 14August, 2020 @reggiegums Is it a correct 914-6 engine, or a 911 engine? Either way it seems like good buying, are you able to post the engine number and type please? Quote Link to comment Share on other sites More sharing options...
Skidmarks Posted 14August, 2020 Report Share Posted 14August, 2020 20 hours ago, 9er said: @reggiegums Is it a correct 914-6 engine, or a 911 engine? Either way it seems like good buying, are you able to post the engine number and type please? How good would this engine look with your wheels! 9er 1 Quote Link to comment Share on other sites More sharing options...
reggiegums Posted 18August, 2020 Author Report Share Posted 18August, 2020 On 14/08/2020 at 09:02, 9er said: @reggiegums Is it a correct 914-6 engine, or a 911 engine? Either way it seems like good buying, are you able to post the engine number and type please? Its a 914-6 engine. Apparently a quick way to know is where its stamped. Apparently stamped in a different location to 911s. I'll revert with the engine no. Quote Link to comment Share on other sites More sharing options...
reggiegums Posted 9September, 2020 Author Report Share Posted 9September, 2020 On 14/08/2020 at 09:02, 9er said: @reggiegums Is it a correct 914-6 engine, or a 911 engine? Either way it seems like good buying, are you able to post the engine number and type please? 6405360 901/38 Quote Link to comment Share on other sites More sharing options...
9er Posted 9September, 2020 Report Share Posted 9September, 2020 Definitely a genuine 914/6 2.0 engine. GC9911 and Oldskl60 2 Quote Link to comment Share on other sites More sharing options...
DJM Posted 1March Report Share Posted 1March Resurrecting this thread, I inherited this engine 6405360 when i bought the 914-6 from @crsedge on here recently. It was suggested above that this is a genuine 914-6 2.0L engine which would mean 80mm x 66mm. But the pistons and cylinders are 90mm bore and heads are from a 2.7, also 90mm bore. OK, so it has pistons, cylinders and heads from a different engine. But i just checked and the spigots in the case are 97mm which is for 90mm bore not the small spigots to suit 80mm bore. The engine number 6405360 sits within the range of 914-6 engine numbers in stuttcars (see below) so that checks out. So what have i got? I assume it must be a genuine 914-6 crankcase that has spigots changed from 92mm to 97mm? The irony is, prior to pulling it all out to take a look, I was researching what's involved to build it into a short stroke 2.5L by changing spigots in the case and sourcing 90mm cylinders, pistons, heads so it could just be that I'm further down that road than expected. Hoping to start the engine build soon but just trying to establish what I've got. First time I’ve played with Porsche engines. I guess the last piece of the puzzle is to confirm it is in fact 66mm crank - any tips on how to check visually? michel 1 Quote Link to comment Share on other sites More sharing options...
