Cracked Steering Wheel
ByronBayChris
The top of my wheel is quite cracked.   What options do I have.
1) New (OEM) wheel
2) New aftermarket wheel (trying to work to a budget for the next few months)
3) Restoring the current wheel using a 3rd party
Any other ideas ?
Thanks
Chris
Don't buy a steering wheel and spend the money on "decision making lessons"  :P
Show us your crack (pun intended) also is your wheel leather? depending of the extent of the cracking it may be DIY repairable…
I've got the same issue - the batwing middle section of my wheel is broken.
Looking at alternatives - they seem very costly which ever route I go!
murf is it worth seeing if someone can braze/weld it then have then repaint it - otherwise they are $$$ as you have discovered.
I recently got my seats "refurbished" and they re-dyed them due to some parts of the leather being very dry and cracked, came out very well.
Looking at the condition your wheel (better than what my seats were), it should be able to be re-furbished to a good standard. Although I would get a referral from someone local so you know your dealing with an experienced trimmer.
