Cayman S tyre pressure
Mike D'Silva
just a question... is there a preference for the first Gen Cayman S tyre pressures?
I have the 19inch Classic rims and tyres..
I'm nearly due for tyres and when I took my rear rims off the other day for a clean, I see that the centre third of the tread is much more worn that the outside thirds... This suggests too high pressure right?
I am running 36psi in the rear... is this too high?
Hi Mike, If the centre section of your tyres are worn down compared to either of the outside sections, it is normally a sign of over inflation.
36 wouldn't be too high IMO I run similar in the Boxster.
However, my rears really do wear out a lot quicker than my fronts, but with relatively even wear across the face of the tyre tread :(
9Fan (Marky Mark) is very switched on   <_< with tyre info, hopefully he will pick this up and let you know.
Anyone knowledgeable beings out there want to suggest re wear pattern or pressure?
  • 6 months later...
  • 1 month later...
I just checked my Boxster and i have the same sticker.
I have my first track day at Sundown on Thursday.
Its going to be a little warm 34 degrees here...
Fronts 30 and rears 37?
should I start at 28 and &34 maybe?
The pressures should go up significantly shouldn't they?
Hi bayf
I like to run 34 in the front and 36 in the back  as I find the boxster seems to favors under steer when its running 30 in the front.
I had a track day at Sandown at the end of August ( very sunny and unseasonably  warm.) and found this to be good on the day.
I am on 17 inch rims.
Starting with cold pressures of 32 front and 34 rear
will see what happens
going to get to 34 tomorrow so I imagine the rack temp will be high.
In reality the way I drive I don't think it will matter  ;)
