Oldskl60 Posted 26December, 2017 Report Share Posted 26December, 2017 Hi Guys My uncle purchased a white 1987 944 turbo a couple months back and has started to play with it a little. We’ve gone the ‘baby steps’ (just wanting a street car that can do a club event once or twice a year) LR route with A-Map, fuel reg, boost enhancer and WG shims. We have been impressed with the results but as usually it highlights other areas that need attending too. We have new Koni yellow adjustible shocks to fit (front and rear) and while we are at it we think it needs some firmer front springs and possibly larger sway bars. Has anyone got a set of heavier springs or s/bars lying around they’d like to sell? We are also chasing the following to help finish it off if anyone has anything they’d part with: - Rear bumper tow hook plug - middle elbow for alternator duct (last bend before the alternator shroud) - 2x black centre console switch deletes - turbo air box or just top lid - wastegate bracket (around torque tube Any advice or assistance greatly appreciated. Kind regards Tom Link to comment Share on other sites More sharing options...
Timm Posted 26December, 2017 Report Share Posted 26December, 2017 My airbox and wastegate bracket will be available soon (in a month or two) after I convert to standalone ecu and after market wastegate...if you haven't gotten anything by then. Link to comment Share on other sites More sharing options...
Oldskl60 Posted 26December, 2017 Author Report Share Posted 26December, 2017 4 hours ago, Timm said: My airbox and wastegate bracket will be available soon (in a month or two) after I convert to standalone ecu and after market wastegate...if you haven't gotten anything by then. Thanks Timm, that sounds great! Link to comment Share on other sites More sharing options...
9fan Posted 27December, 2017 Report Share Posted 27December, 2017 21 hours ago, Oldskl60 said: Rear bumper tow hook plug If you don't mind after market and black - Clark Rubber has a rubber body plug that fits. Cheers, Mark. Link to comment Share on other sites More sharing options...
OzJustin Posted 27December, 2017 Report Share Posted 27December, 2017 In case you decide to purchase directly from Porsche, these part numbers might help for a couple of those cheap items. They're on my 'to buy' list too. Rear tow hook cover - 951.505.349.00 Centre console switch blank - 944-613-259-02-1DB Link to comment Share on other sites More sharing options...
Pauly Posted 27December, 2017 Report Share Posted 27December, 2017 This is the most common sway bar upgrade. It's common because it's the best sway bar upgrade you can do for a street car. https://www.lindseyracing.com/LR/Parts/944SWAYMO30.html After that, you'll be looking at these https://www.lindseyracing.com/LR/Parts/944SWAYBARTARETT.html Link to comment Share on other sites More sharing options...
Oldskl60 Posted 27December, 2017 Author Report Share Posted 27December, 2017 12 hours ago, 9fan said: If you don't mind after market and black - Clark Rubber has a rubber body plug that fits. Cheers, Mark. Good to know Mark, thank you I’ll check it out. 8 hours ago, OzJustin said: In case you decide to purchase directly from Porsche, these part numbers might help for a couple of those cheap items. They're on my 'to buy' list too. Rear tow hook cover - 951.505.349.00 Centre console switch blank - 944-613-259-02-1DB Thanks Justin! 6 hours ago, Pauly said: This is the most common sway bar upgrade. It's common because it's the best sway bar upgrade you can do for a street car. https://www.lindseyracing.com/LR/Parts/944SWAYMO30.html After that, you'll be looking at these https://www.lindseyracing.com/LR/Parts/944SWAYBARTARETT.html Pauly sounds like the MO30 is the way to go although the tarrets look damn hot (just not the path for this car). Thanks for the feedback. Link to comment Share on other sites More sharing options...
OzJustin Posted 28December, 2017 Report Share Posted 28December, 2017 I'm running the 968 MO30 sway bars on my S2 and can attest to them being excellent for a street/track car. Link to comment Share on other sites More sharing options...
Oldskl60 Posted 28December, 2017 Author Report Share Posted 28December, 2017 7 hours ago, OzJustin said: I'm running the 968 MO30 sway bars on my S2 and can attest to them being excellent for a street/track car. Thanks for the confirmation! Sounds like a sure thing? Link to comment Share on other sites More sharing options...
Kelly Posted 14January, 2018 Report Share Posted 14January, 2018 Did you end up sorting a sway bar? Link to comment Share on other sites More sharing options...
Timm Posted 14January, 2018 Report Share Posted 14January, 2018 1 hour ago, Kelly said: Did you end up sorting a sway bar? Do you have some? I'd be interested if Tom doesn't need them. Link to comment Share on other sites More sharing options...
944s2cab Posted 14January, 2018 Report Share Posted 14January, 2018 25 minutes ago, Timm said: Do you have some? I'd be interested if Tom doesn't need them. ditto Link to comment Share on other sites More sharing options...
Kelly Posted 15January, 2018 Report Share Posted 15January, 2018 I have a Weltmeister adjustable front sway bar (like attached pic) which I have been running on my car for ages. I'm contemplating selling it to offset the $1300 cost of bringing in a light weight Tarret front sway bar. Link to comment Share on other sites More sharing options...
Buchanan Automotive Posted 15January, 2018 Report Share Posted 15January, 2018 Hi Kelly, We have fitted a few of those Tarrett sway bars and can attest there is nothing light about them. They are just as heavy if not a little more then those aftermarket solid 30mm units. The best unit i have seen was made by Paul at evolution motorsport for Patricks time attack car, It was a hollow bar with blade ends. message Patrick and see if he has any pictures Regards Sean Link to comment Share on other sites More sharing options...
Kelly Posted 16January, 2018 Report Share Posted 16January, 2018 13 hours ago, Buchanan Automotive said: Hi Kelly, We have fitted a few of those Tarrett sway bars and can attest there is nothing light about them. They are just as heavy if not a little more then those aftermarket solid 30mm units. The best unit i have seen was made by Paul at evolution motorsport for Patricks time attack car, It was a hollow bar with blade ends. message Patrick and see if he has any pictures Regards Sean Hey Sean, Thanks for that very significant tip. I'd have been pretty unhappy to discover that the hard way. Cheers Kelly Link to comment Share on other sites More sharing options...
Oldskl60 Posted 16January, 2018 Author Report Share Posted 16January, 2018 15 hours ago, Kelly said: I have a Weltmeister adjustable front sway bar (like attached pic) which I have been running on my car for ages. I'm contemplating selling it to offset the $1300 cost of bringing in a light weight Tarret front sway bar. Thanks Kelly, we haven't found anything yet so I will PM you! Link to comment Share on other sites More sharing options...
