Blue964 Posted 14June, 2021 Report Posted 14June, 2021 No idea where to post this, but it does relate to a air-cooled 911 so figure this is as good a place to post as any. Can anyone recommend a good quality mobile phone holder that will fit up to a 993 dash? Don't want a window stick on. Quote
LeeM Posted 14June, 2021 Report Posted 14June, 2021 Just saw this on an Instagram page I follow Just pop out ya clock and ya done Blue964 1 Quote
autojack Posted 14June, 2021 Report Posted 14June, 2021 That's the Rennline one. At $75 USD, it was too rich for my blood I got a springy one which clips into the vent for about $10. https://www.rennline.com/Porsche-911-ExactFit-Magnetic-Phone-Mount/productinfo/PM01.06/ Quote
Andy73 Posted 15June, 2021 Report Posted 15June, 2021 If you're driving on the twisties you want a good solid mount. I run the Rennline mount in both my 911's and rate it. The earlier magnets weren't as strong as they needed to be, but the newer versions work a treat - even on the twisties, the phone stays put and it's nice and neat. Very happy with mine. Blue964 1 Quote
Blue964 Posted 15June, 2021 Author Report Posted 15June, 2021 1 hour ago, Andy73 said: If you're driving on the twisties you want a good solid mount. I run the Rennline mount in both my 911's and rate it. The earlier magnets weren't as strong as they needed to be, but the newer versions work a treat - even on the twisties, the phone stays put and it's nice and neat. Very happy with mine. That's exactly what I want...something that will hold up to the twisties. My suspension setup is pretty stiff too so need to put up with lots of bumps and jumps 20 hours ago, LeeM said: Just saw this on an Instagram page I follow Just pop out ya clock and ya done I really like the look of that. I'll check it out. Thanks LeeM 1 Quote
luzzo Posted 15June, 2021 Report Posted 15June, 2021 1 hour ago, Andy73 said: I run the Rennline mount in both my 911's and rate it. Thanks for the recommend, was looking for a good solution. The 996 fitment is very clever. I was concerned it may affect the console/trim, but the video show how well it's done. Quote
Scott930 Posted 15June, 2021 Report Posted 15June, 2021 3 hours ago, Andy73 said: If you're driving on the twisties you want a good solid mount. I run the Rennline mount in both my 911's and rate it. The earlier magnets weren't as strong as they needed to be, but the newer versions work a treat - even on the twisties, the phone stays put and it's nice and neat. Very happy with mine. Does the metal/steel mounting pad that you need to put in/on the phone cover affect wireless phone charging at all? Quote
pocketscience Posted 18June, 2021 Report Posted 18June, 2021 I've got that Rennline mount in my 993 and 901. It's pretty good. I upgraded mine by replacing the standard magnetic mount with a iPhone Magsafe charger - so it still holds the phone by magnet, but charges as well without having to think about it. Routed the cabling so it's basically invisible. Quote
YellowDieselGolf Posted 20June, 2021 Report Posted 20June, 2021 Do you have details on your charger @pocketscience? I'd like a solution that's Qi and magnet compatible. The problem with the rennline mount is that the metal strip (that goes in your phone case) works best when it's in the centre of the phone - right where it blocks the Qi antenna. I've placed the strip at the top (near the camera) so I can use a home Qi charger, but this means the phone isn't stable on the rennline mount. Quote
pocketscience Posted 20June, 2021 Report Posted 20June, 2021 23 hours ago, YellowDieselGolf said: Do you have details on your charger @pocketscience? I'd like a solution that's Qi and magnet compatible. The problem with the rennline mount is that the metal strip (that goes in your phone case) works best when it's in the centre of the phone - right where it blocks the Qi antenna. I've placed the strip at the top (near the camera) so I can use a home Qi charger, but this means the phone isn't stable on the rennline mount. This is the charger I've used: https://www.ebay.com.au/itm/193898952751?var=494112566501 YellowDieselGolf 1 Quote
