FlatSix Posted 2December, 2013 Report Share Posted 2December, 2013 Hey all, after a great day of sliding all over the place at the skidpan on Saturday I now have a slight water issue. On the way home I turned on the stereo and my rear speakers started popping and crackling. The amp for the rears is mounted under the drivers seat, so I had a look and the floor is saturated :0. The amp has been glued to the floor insulation (???) and when i push down on the floor water just oozes out. So my question is, does anyone have any effective solutions for removing the water, or is getting someone in with a water extractor my only way to go? Link to comment Share on other sites More sharing options...
Russ Posted 2December, 2013 Report Share Posted 2December, 2013 if you can get a heap of silica crystals in bowls and leave them in the car, and get some airflow going (which is probably what the extraction systems do anyway) maybe with the combo of a wetvac I pulled all my carpets and insulation out to get them to dry - I think mine came in under the dash from the bonnet seal Link to comment Share on other sites More sharing options...
OZ930 Posted 2December, 2013 Report Share Posted 2December, 2013 would kitty litter do the same job ? Link to comment Share on other sites More sharing options...
Russ Posted 2December, 2013 Report Share Posted 2December, 2013 yeah I think so, if you get the silica based one (not the crushed paper one) The silica just absorbs moisture from the air and I've seen it in cars in long term storage in large blocks I'd see if you can get the mats out, then get a wet vac to wash the stale water out, then get a heap of bowls of silica and some airflow (or some professional extraction) lol Link to comment Share on other sites More sharing options...
hugh Posted 2December, 2013 Report Share Posted 2December, 2013 Newspaper can absorb quite a bit if you can pull up the carpet and lay some down? Link to comment Share on other sites More sharing options...
FlatSix Posted 2December, 2013 Author Report Share Posted 2December, 2013 hmmm thanks for your tips guys, I have a very large tub of damp-rid I will throw in there plus some newspaper to soak up what I can. Link to comment Share on other sites More sharing options...
G5032 Posted 4December, 2013 Report Share Posted 4December, 2013 I had a damp spot in the drivers footwell after enduring 6 hours of torrential rain when I drove back from Adelaide where I purchased the car..I pulled back the carpet and soaked up as much as icould with rags then gave it a thorough blowdry with the hairdryer until everything was bone dry...haven't driven in the rain since!! Link to comment Share on other sites More sharing options...
TINGY Posted 5December, 2013 Report Share Posted 5December, 2013 Oh Bugger your car will probably be fogging up all the time now. What about one of those little electric heaters that you put under a desk to help dry it out. Link to comment Share on other sites More sharing options...
Airhead Posted 5December, 2013 Report Share Posted 5December, 2013 Drill a hole in the floor? Link to comment Share on other sites More sharing options...
CarreraG50 Posted 5December, 2013 Report Share Posted 5December, 2013 Drill a hole in the floor? PFFFT just wait for the rust to do the job for you, zero effort required. Link to comment Share on other sites More sharing options...
Airhead Posted 5December, 2013 Report Share Posted 5December, 2013 That's what we do with English cars. Link to comment Share on other sites More sharing options...
FlatSix Posted 5December, 2013 Author Report Share Posted 5December, 2013 I've managed to get most of it out with newspaper, heat gun and the biggest bucket of damprid I have ever seen. I think the amp for the rear speakers is toast but the 4 channel running the fronts is fine. I think I will just wire the rears into that. 2 seperate amps under the seat seem overkill for a seldom used component anyway It should be all dried out in time for round 2 in March! Link to comment Share on other sites More sharing options...
Russ Posted 5December, 2013 Report Share Posted 5December, 2013 do you know where the water came in? Link to comment Share on other sites More sharing options...
FlatSix Posted 6December, 2013 Author Report Share Posted 6December, 2013 Not sure Russ, I cant see anything from inside as the floor is covered in insulation. I need to have a look under the car. A trip up to Kens place might be on the cards soon. Link to comment Share on other sites More sharing options...
OZ930 Posted 6December, 2013 Report Share Posted 6December, 2013 While you have the carpets out, try a dark shed and shine a light from underneath and look inside for light shining through, might show up something. Just a thought Link to comment Share on other sites More sharing options...
Flatout Posted 20December, 2013 Report Share Posted 20December, 2013 I had an old beema years ago that did that. Turned out that the drain tubes for the sunroof had clogged up & somehow all the water was running down and ending up in the floor behind the passenger seat in my case. Link to comment Share on other sites More sharing options...
Russ Posted 20December, 2013 Report Share Posted 20December, 2013 lol, I've got water in my torsion bar tubes making them squeak Link to comment Share on other sites More sharing options...
FlatSix Posted 21December, 2013 Author Report Share Posted 21December, 2013 I will try the light trick, the water definitely came in from underneath. Russ some hard cornering might get the water out Link to comment Share on other sites More sharing options...
Coastr Posted 22December, 2013 Report Share Posted 22December, 2013 I had an old beema years ago that did that. Turned out that the drain tubes for the sunroof had clogged up & somehow all the water was running down and ending up in the floor behind the passenger seat in my case. The trick to fix this one is whipper snipper line, fed down the tubes like a drain snake, until they unclog. And thn never, ever , park your car under a tree. Link to comment Share on other sites More sharing options...
