pocketscience Posted 21January, 2014 Report Share Posted 21January, 2014 This is a basic job, but without the right tools it's a bit tricky... anyway, documenting for those that might need to do the same at some point. 1. Buy a cable like this from ebay - this one cost $5.99 with free shipping. 2. Build yourself some removal pins using your finest eye measurements, a coat hanger and a pair of snips. Basically you need the pins to insert cleanly into the two holes on either side of the stereo unit 3. Remove the front faceplate (optional, but I didn't want to accidentally scratch it) 4. Insert the pins until you feel them pass a friction point which should be the locking mechanism- approx 50-60mm into the holes The locking mechanism before pins inserted (this was taken with the stereo out for illustrative purposes!) Pins inserted 5. With the factory pins you press outwards on the pins and pull the stereo out, but with the coat hanger pins that didn't work, so I simply reached in behind the dash and pushed the stereo from behind. It came out without a single swear-word being uttered. 6. The cables connected to the stereo aren't very long, so you can't remove it out very far - but there's enough to rotate the unit and reach in and connect the aux input cable. 7. Feed the remainder of the cable in behind the stereo and pull it through and down so it's accessible from below the dash. 8. Re-insert stereo, plug in your audio device of choice and pump up the volume! My plan is to hook up an Airport Express so I can stream music over Wifi, so getting the aux cable connected is step 1 of that project. Cheers, Link to comment Share on other sites More sharing options...
Pauly Posted 21January, 2014 Report Share Posted 21January, 2014 Link to comment Share on other sites More sharing options...
pocketscience Posted 21January, 2014 Author Report Share Posted 21January, 2014 Yup..! Link to comment Share on other sites More sharing options...
Pauly Posted 21January, 2014 Report Share Posted 21January, 2014 Airplay would be good for you as you don't have iPod/iPhone connectivity. I thought about it, But because I do have that feature, I'd find it that it just would be an inconvenience playing with my phone to change the song when I can do it via the headunit. Cool though when you can say "check this out" to your friends Link to comment Share on other sites More sharing options...
pocketscience Posted 21January, 2014 Author Report Share Posted 21January, 2014 Airplay would be good for you as you don't have iPod/iPhone connectivity. I thought about it, But because I do have that feature, I'd find it that it just would be an inconvenience playing with my phone to change the song when I can do it via the headunit. Cool though when you can say "check this out" to your friends Especially when it'll look totally stock! Link to comment Share on other sites More sharing options...
withers Posted 21January, 2014 Report Share Posted 21January, 2014 Cool! Great write up Link to comment Share on other sites More sharing options...
SteveT Posted 21January, 2014 Report Share Posted 21January, 2014 Those guys at mighty car mods seem to have some interesting ideas. And Aussie as well! Link to comment Share on other sites More sharing options...
tony1 Posted 21January, 2014 Report Share Posted 21January, 2014 another alternative is to source an fm transmitter for around $7-00 and plug that into the base of the ipod/iphone then listen through the stereo. Im hoping it will give a better quality sound then the old 3mm pin that I had to use in the work hilux Link to comment Share on other sites More sharing options...
Pauly Posted 21January, 2014 Report Share Posted 21January, 2014 Those guys at mighty car mods seem to have some interesting ideas. And Aussie as well! Take an hour or so and watch a few of their videos. They do some pretty interesting stuff! another alternative is to source an fm transmitter for around $7-00 and plug that into the base of the ipod/iphone then listen through the stereo. Im hoping it will give a better quality sound then the old 3mm pin that I had to use in the work hilux i have a belkin transmitter. It's good. But has it's flaws. It was $60. My mate picked up a cheaper brand one and the quality just went down. Link to comment Share on other sites More sharing options...
pocketscience Posted 22January, 2014 Author Report Share Posted 22January, 2014 The MCM guys take a lot of credit but that AirPlay hack has been around on other forums for a while... MCM do a nice presentation of it although they really should give some credit to the original work.. I was going to use a Bluetooth dongle I have that handles audio, but BT audio is compressed so the Wifi option is much better. The FM transmitters work OK too I guess... but the one I have (cheap ebay job) didn't give a very clean signal hence the hunt for something better. Mind you now that I have the cable... part of me says "why do you need anything else?". Of course the correct answer is "because I can". Cheers, Link to comment Share on other sites More sharing options...
SteveT Posted 22January, 2014 Report Share Posted 22January, 2014 I just recently had a Pioneer head unit installed. Got all those goodies now plus satnav, DAB+, can watch DVDs. Mostly I just curse radio for too many ads though just like with my original radio. Link to comment Share on other sites More sharing options...
pocketscience Posted 20February, 2014 Author Report Share Posted 20February, 2014 Finally got the Airport Express hooked up so I now have AirPlay in my 993 - sweet! I did it a bit different to the MCM guys - I used a more sturdy 12v/3.3v regulator pack that fits neatly inside the AirPort Express so no USB adaptor messing about. The whole thing is hidden up under the dash, so you can't see a thing. I did orient the AEX so I can see the power LED if I stick my head under the dash. Link to comment Share on other sites More sharing options...
Airhead Posted 20February, 2014 Report Share Posted 20February, 2014 I have absolutely NO IDEA what any of you are talking about. Link to comment Share on other sites More sharing options...
StevepGT3 Posted 20February, 2014 Report Share Posted 20February, 2014 Finally got the Airport Express hooked up so I now have AirPlay in my 993 - sweet! I did it a bit different to the MCM guys - I used a more sturdy 12v/3.3v regulator pack that fits neatly inside the AirPort Express so no USB adaptor messing about. The whole thing is hidden up under the dash, so you can't see a thing. I did orient the AEX so I can see the power LED if I stick my head under the dash. That`s really cool, that tech wasn`t available when I installed an Alpine I pod/ radio player in mine, keep us updated on how well it all works as I may do the same to my std system Link to comment Share on other sites More sharing options...
Orion03 Posted 20February, 2014 Report Share Posted 20February, 2014 I used to work for Blaupunkt. Link to comment Share on other sites More sharing options...
pocketscience Posted 20February, 2014 Author Report Share Posted 20February, 2014 Steve, it works really well - it's powered from the same line as the stereo and only take 20-30 seconds to boot up - then away it goes. Very easy mod. Link to comment Share on other sites More sharing options...
withers Posted 21February, 2014 Report Share Posted 21February, 2014 I used to work for Blaupunkt. And? Is there more to this??? Link to comment Share on other sites More sharing options...
T-Man Posted 27February, 2014 Report Share Posted 27February, 2014 I'm thinking you have a different model to my radio. Possibly and 1996 onwards.I have a RD104 and can;t possibly find where a line in could be. Link to comment Share on other sites More sharing options...
