AC78 Posted 30September, 2014 Report Share Posted 30September, 2014 A question for the brains trust, having removed all my AC hoses I'm left with dozens of screw hole in the underside of the car and inside wheel arches. So as these areas are quite vulnerable to moisture and dirt, what is the best way to plug these holes? Is there some sort of filler I can buy, or will it suffice to simply put all the screws back in again (minus the brackets that held the hose)?? Cheers, Alex Link to comment Share on other sites More sharing options...
LeeM Posted 30September, 2014 Report Share Posted 30September, 2014 There are some plugs you can buy for exposed screw holes, but I'm not sure how small or big they are or where to buy them. An easy fix would be to put a dab of appropriate silicone on the screws and refit them Link to comment Share on other sites More sharing options...
firstone Posted 30September, 2014 Report Share Posted 30September, 2014 I would just put the fasteners back in place. It will be as it was formerly. Link to comment Share on other sites More sharing options...
tazzieman Posted 1October, 2014 Report Share Posted 1October, 2014 I did as Lee suggested Link to comment Share on other sites More sharing options...
Harvs11 Posted 1October, 2014 Report Share Posted 1October, 2014 I did the same, just refitted the screws. Link to comment Share on other sites More sharing options...
Russ Posted 1October, 2014 Report Share Posted 1October, 2014 just throw the screws back in, maybe with a little sealant. I'd be tempted to weld them back up, but then you'd have to treat it (and it might be difficult to get to the other side) Link to comment Share on other sites More sharing options...
firstone Posted 1October, 2014 Report Share Posted 1October, 2014 Beware some silicone has corrosive elements in them. Link to comment Share on other sites More sharing options...
Airhead Posted 1October, 2014 Report Share Posted 1October, 2014 Link to comment Share on other sites More sharing options...
LeeM Posted 1October, 2014 Report Share Posted 1October, 2014 Beware some silicone has corrosive elements in them. I was just about to edit my post with the same advice Link to comment Share on other sites More sharing options...
Peter M Posted 1October, 2014 Report Share Posted 1October, 2014 Alex, Wouldn't most of the holes be through the two seams that run up both sides of the floor pan where the side members are spot welded to the pan? ie. so the holes won't actually allow water inside the car even if you leave them be. I'd use brushable seam sealer to fill the holes if they are not to big. You can also stipple the surface so it looks like the original stonechip coating. If it was me I'd put the AC back in as it was 33 here yesterday and it's only going to get hotter! Link to comment Share on other sites More sharing options...
AC78 Posted 2October, 2014 Author Report Share Posted 2October, 2014 Thanks for the suggestions all. Think I will plug holes with original screws and a touch of silicone. Peter, screw holes are straight into the floor pan next to the oil lines. My AC never worked anyway and I'm a windows down kinda driver. Link to comment Share on other sites More sharing options...
