Digital Mouth Posted 12November, 2014 Report Share Posted 12November, 2014 What is this bizarre noise coming from my Exhaust? Link to comment Share on other sites More sharing options...
Harvs11 Posted 12November, 2014 Report Share Posted 12November, 2014 Sounds like a belt buckle going around in the clothes dryer, but more likely it's $$$ Sorry, but I can't imagine it's anything else. Link to comment Share on other sites More sharing options...
Pauly Posted 12November, 2014 Report Share Posted 12November, 2014 if you have a cat. it's probably that. a piece broken inside. Link to comment Share on other sites More sharing options...
GC9911 Posted 12November, 2014 Report Share Posted 12November, 2014 Sounds like a loose baffle plate in the muffler? Link to comment Share on other sites More sharing options...
Digital Mouth Posted 12November, 2014 Author Report Share Posted 12November, 2014 I have no idea to be honest. It was fine before I took it down to my Mechanic for a wheel alignment and balance and then this. Maybe it's something he's done. I'll find out tomorrow when I go to see him again. Link to comment Share on other sites More sharing options...
Caver Posted 12November, 2014 Report Share Posted 12November, 2014 See if you can get further under the car to localise the noise. Back it over the edge of the gutter and slide under or get the mechanic to do it. Probably in one of the catalytic converters. Link to comment Share on other sites More sharing options...
Airhead Posted 13November, 2014 Report Share Posted 13November, 2014 The mouse got out? Link to comment Share on other sites More sharing options...
firstone Posted 13November, 2014 Report Share Posted 13November, 2014 Kid dropped a stone into the tailpipe. Link to comment Share on other sites More sharing options...
OZ930 Posted 13November, 2014 Report Share Posted 13November, 2014 …..an excuse to get a sports system Link to comment Share on other sites More sharing options...
JustJames Posted 14November, 2014 Report Share Posted 14November, 2014 If it is something loose in the zorst, you should be able to feel it. With a COLD car feel for percussion. I'll repeat - exhausts get hot, you've got a minute or thereabout after startup, with the car properly cold before it is warm enough to do serious damage. Always be very careful with advice provided over the internetz 'cause if you hurt yourself you have only yourself to blame! (Last bit there for posterity DM, not directed at you. Unless you burn your hand.) Link to comment Share on other sites More sharing options...
Caver Posted 14November, 2014 Report Share Posted 14November, 2014 Geez Adrian...it's not like you can even use the sound for a mix???!!!! Link to comment Share on other sites More sharing options...
au-yt Posted 15November, 2014 Report Share Posted 15November, 2014 I just recon its just a Baffling noise.... Link to comment Share on other sites More sharing options...
Tit Posted 15November, 2014 Report Share Posted 15November, 2014 *groan* I just recon its just a Baffling noise.... Link to comment Share on other sites More sharing options...
