Mike D'Silva Posted 23January, 2016 Report Share Posted 23January, 2016 just saw this on Gumtree...http://www.gumtree.com.au/s-ad/salisbury/other-automotive/portable-mini-scissor-lift-spider-2500/1060054078Anyone seen in the flesh? Might be adequate to get the rear end high enough for engine removals in a 911? Link to comment Share on other sites More sharing options...
Stew F Posted 23January, 2016 Report Share Posted 23January, 2016 Looks pretty good, and reasonably priced. Not sure if it can be done, but if you could uncouple the drive shaft between the worm boxes you could raise it on one side only as well. Link to comment Share on other sites More sharing options...
MFX Posted 23January, 2016 Report Share Posted 23January, 2016 It looks ok, but a 2 post hoist is only few hundred more... Link to comment Share on other sites More sharing options...
Raven Posted 23January, 2016 Report Share Posted 23January, 2016 You can get two post hoists for as little as $2000 these days ,,,I Don,t know how good they are and they are most likely made in China ,,,but still something to look into ...alternatively you can spend $3000 and get a half decent one ........... Link to comment Share on other sites More sharing options...
Mike D'Silva Posted 23January, 2016 Author Report Share Posted 23January, 2016 Only considering something like this due to height constraints.... Link to comment Share on other sites More sharing options...
LeeM Posted 23January, 2016 Report Share Posted 23January, 2016 Good ide, yet I'd want some jack stands under that for peace of mind Link to comment Share on other sites More sharing options...
Fraz Posted 24January, 2016 Report Share Posted 24January, 2016 I have seen one of these personally, lot more substantial and stronger than I was expecting. http://www.ebay.com.au/ulk/itm/121578081747 Link to comment Share on other sites More sharing options...
SteveT Posted 26January, 2016 Report Share Posted 26January, 2016 No way I would get under a car only supported by that lift. Maybe use it to get the car off the ground but axle stands would be used to make sure it stays up until I wanted it to come down. Link to comment Share on other sites More sharing options...
