symsy Posted 28April, 2017 Report Share Posted 28April, 2017 Home in the hood . Hot wasser cooled metal parked in the garage... However Hot metal has flat battery and has parked A/C car in.. nose to tail unfortunatleyMy laugh and question ..no peeking in manuals or googling..How do you think one opens the bonnet to jump start the car??? A 997? Damn technology!!I am not going to give Porsche a design award for this one.....Your answers ??If you dont know ..guess .. I have had 30 years with porsche and even fandangled electrical genius of Landrover but this ones awesomeThe follow up question , if per chance you did have a flat battery and had the key in the ignition like ..the only key and you want to remove it to walk away from your car and lock it manually.. how do you remove that said key to do so?? Link to comment Share on other sites More sharing options...
P-Kay Posted 28April, 2017 Report Share Posted 28April, 2017 Buddy....You're screwed If memory serves, you need to jump at the fuse panel and I'm pretty sure if the battery is flat, then you can't remove the key.C-Tek is your saviour - in fact it is a must with a 997 onward as too many gizmos.Good luck brother - good luck! Link to comment Share on other sites More sharing options...
D2000 Posted 28April, 2017 Report Share Posted 28April, 2017 Attach negative jumper cable to terminal in fuse box and then press hood release button? Or find the manual release in the wheel well? Link to comment Share on other sites More sharing options...
StevepGT3 Posted 28April, 2017 Report Share Posted 28April, 2017 open door with key and read manual Link to comment Share on other sites More sharing options...
Dreamr Posted 28April, 2017 Report Share Posted 28April, 2017 open door with key and read manualOnly key is in the ignition and can't be removed .... you didn't think it would be that easy a solution did you .... this is Symsy after all!! ..... Link to comment Share on other sites More sharing options...
StevepGT3 Posted 28April, 2017 Report Share Posted 28April, 2017 Only key is in the ignition and can't be removed .... you didn't think it would be that easy a solution did you .... this is Symsy after all!! ..... No one is that stupid. Link to comment Share on other sites More sharing options...
symsy Posted 28April, 2017 Author Report Share Posted 28April, 2017 No one is that stupid.I know where you live.... The other key is in Melbourne , shall I come get it Link to comment Share on other sites More sharing options...
StevepGT3 Posted 28April, 2017 Report Share Posted 28April, 2017 I know where you live.... The other key is in Melbourne , shall I come get it Bring it on Bovver Boy. Link to comment Share on other sites More sharing options...
symsy Posted 28April, 2017 Author Report Share Posted 28April, 2017 Bring it on Bovver Boy. If I come down there and get in your motor im stealing the leather centre console... Link to comment Share on other sites More sharing options...
StevepGT3 Posted 28April, 2017 Report Share Posted 28April, 2017 If I come down there and get in your motor im stealing the leather centre console...I will also give you my spare key to take up to Byron for safe keeping Link to comment Share on other sites More sharing options...
Stew F Posted 28April, 2017 Report Share Posted 28April, 2017 Big arse jimmy bar? Link to comment Share on other sites More sharing options...
TINGY Posted 28April, 2017 Report Share Posted 28April, 2017 No one is that stupid.Apparently the answer to that is, yes they (he is) are. Link to comment Share on other sites More sharing options...
Raven Posted 28April, 2017 Report Share Posted 28April, 2017 I have had this happen in my 997 ASS PAIN ............you need another separate battery and you hook it up to the terminal in the fuse box for this purpose with a jumper cable to the positive side of the battery ,,,,then you hook the neg side of the battery to the cars door lock pin to ground the circuit ,,,this then allows you to open the front trunk and get to the flat battery ...........It is a horses ass and you would think they would have a manual release or some sort of micro switch that works on very low voltage to open the front trunk ....As a result of this under engineered process I always make sure my car is on a battery tender ,,,,it only takes about a month and the battery gets to low to crank the car over ,,,,too much electrical crap dependent on constant power is the problem .... Link to comment Share on other sites More sharing options...
Stephen Tinker Posted 28April, 2017 Report Share Posted 28April, 2017 ^^^ What Raven says ^^^^The fuse box is located just above your your right ankle joint. When you pull off the cover, there should be a multi-page circuit diagram listing the fuses and a picture of the pull out connector to attach the (+) side of your battery. The (-) side attaches to the door hinge or lock pin (or any good earth) - just make sure there is no paint or grease on the frame metal connection.Be aware that you cannot leave the key in the ignition for any length of time, that will flatten the battery within 24 hours - ask me how I know.....Failing all that, there (should) be a nylon pull wire behind the drivers front wheel well plastic cover - of course you need to jack up the car & remove the wheel and cover, but the jack and wheel spanner(s) (does it have wheel security bolts) are in the front boot !! Which is locked.... Link to comment Share on other sites More sharing options...
