dan_189 Posted 9June, 2017 Report Share Posted 9June, 2017 Hey all,Anyone use a Motive Power bleeder to bleed their clutch system? I'm going to replace my clutch master cylinder soon so i'll need to bleed the clutch system. Over in the US Motive seems to be the product of choice, haven't found it easy to find one over here, anyone ever used a similar bleeding product? Anyone have any experience in bleeding their clutch system on a 996/986/997/987 with a decent tool? Not really interested in doing it by hand i'd prefer to invest in a tool, they aren't that expensive. Link to comment Share on other sites More sharing options...
Fraz Posted 9June, 2017 Report Share Posted 9June, 2017 You could try a speed bleeder, fantastic idea work a treat. Also work on clutches.http://www.speedbleeder.com/ Link to comment Share on other sites More sharing options...
Russ Posted 9June, 2017 Report Share Posted 9June, 2017 Used one on 964 brakes, imagine it'd be much the same on anything else.my old man bought this one for his Merc's from FCP euro - https://www.fcpeuro.com/products/power-brake-bleeder-motive-mot0100 Link to comment Share on other sites More sharing options...
Rob Posted 9June, 2017 Report Share Posted 9June, 2017 Got mine from FCP too - very good on postage rates compared with Pelican and Paragon. Used to good effect on 2x 944S2 clutch bleeds - ask Jason and Justin. Save yourself a bit of time and partially bleed the M/C before you screw in the hard line to the slave... Link to comment Share on other sites More sharing options...
dan_189 Posted 9June, 2017 Author Report Share Posted 9June, 2017 Thanks all, the motive is the one i'm looking at also, there is an Australian supplier in NSW listed on the motive website but the website doesn't exist anymore. The slave was replaced by PCM but then the master gave way a few days later so i'll be doing that but have to bleed it at the slave end anyway.First step i'll do is remove all the fluid from the reservoir below the feed line to the master, remove it and replace it. Then ill do a positive pressure bleed at the slave with the motive. Link to comment Share on other sites More sharing options...
firstone Posted 9June, 2017 Report Share Posted 9June, 2017 I couldn't find one local when I did my 986.I bought a large 60ml syringe from the horse place and vacuum tube from repco. Cleaned the bleeder on the slave, and pushed the fluid in through it. Fill the master half or so first One full syringe was enough. They were 60c for two.Keep in mind that the bleeder will twist shut if not open enough, but you don't want it so far open that it leaks out the thread.I know it's not worthy of the Porsche, but it works. Car back on the road same day ? Link to comment Share on other sites More sharing options...
StevepGT3 Posted 9June, 2017 Report Share Posted 9June, 2017 I have had a Motive for years and it has been used for brake and some clutch bleeds on everything from my 74 105 split braking system Alfa, which was only thing that would get a good pedal on that car, to old pommy TVR`s and Scimitar`s, 3.2 carrera ,64 Ford thunderbird, home built clubman , motorbikes ,Audi A6, Pajero and 993.Without doubt one of the best garage accessories money can buy,and it actually works. Link to comment Share on other sites More sharing options...
James P Posted 10June, 2017 Report Share Posted 10June, 2017 @dan_189 it will be almost impossible to bleed the clutch system without a power bleederI replaced my clutch master cylinder last week on my 996 cupThis is the bleeder i have & use http://www.ebay.com.au/itm/SP-Tools-Brake-Clutch-Pressure-Bleeding-Kit-SP70809-/251932102617?_trksid=p2385738.m2548.l4275 works very well for clutch & brakes... available in Australia Just follow the factory procedure to bleed the clutch system after component replacement Link to comment Share on other sites More sharing options...
dan_189 Posted 10June, 2017 Author Report Share Posted 10June, 2017 Thanks all, definitely need one as I'll be doing the clutch master cylinder soon. Good to hear some positive re-enforcement regarding power/positive pressure bleeding Link to comment Share on other sites More sharing options...
StevepGT3 Posted 10June, 2017 Report Share Posted 10June, 2017 @dan_189 it will be almost impossible to bleed the clutch system without a power bleeder I replaced my clutch master cylinder last week on the cup car This is the bleeder i have & use http://www.ebay.com.au/itm/SP-Tools-Brake-Clutch-Pressure-Bleeding-Kit-SP70809-/251932102617?_trksid=p2385738.m2548.l4275 works very well & available in Australia Just follow the factory procedure to bleed the clutch system after component replacement That looks even better than the Motive, having a pressure release valve and a separate filler cap. Link to comment Share on other sites More sharing options...
