TheBaywatchKid Posted 10January, 2022 Report Share Posted 10January, 2022 Hi Friends. I had Autohaus do a Major service on my car last year, and have just booked in for another. Was accelerating past someone yesterday and all of a sudden the engine started making a knocking noise. Took a short video, anyone have any ideas what it could be? 67E1712D-91BE-4F43-9468-FD493BD4EB8D-44256-000004CBBF23105D.mov Quote Link to comment Share on other sites More sharing options...
P-Kay Posted 10January, 2022 Report Share Posted 10January, 2022 If I'm not mistaken, you have a hole in your exhaust TheBaywatchKid 1 Quote Link to comment Share on other sites More sharing options...
TheBaywatchKid Posted 10January, 2022 Author Report Share Posted 10January, 2022 Oh interesting. I'll take a look later with a proper light and check for some holes. That would be a dream compared to what I've been imagining! 12 minutes ago, P-Kay said: If I'm not mistaken, you have a hole in your exhaust Quote Link to comment Share on other sites More sharing options...
MFX Posted 10January, 2022 Report Share Posted 10January, 2022 Yep. Sounds like an exhaust leak to me too. My guess is either you have a cracked header or blown an exhaust gasket. Either one is a pretty cheap simple fix in air cooled land TheBaywatchKid 1 Quote Link to comment Share on other sites More sharing options...
TheBaywatchKid Posted 10January, 2022 Author Report Share Posted 10January, 2022 Hmm just had a look at the Gaskets and saw this, with a little oil around on the bracket below. Might be the culprit? Thanks for all your help! Quote Link to comment Share on other sites More sharing options...
LeeM Posted 10January, 2022 Report Share Posted 10January, 2022 If you can reach it easily, CAREFULLY put your hand over the area when it's running to see if you can feel the leak. (disclaimer. No responsibility taken if you burn ya hand!) TheBaywatchKid and MFX 1 1 Quote Link to comment Share on other sites More sharing options...
TheBaywatchKid Posted 10January, 2022 Author Report Share Posted 10January, 2022 2 hours ago, LeeM said: If you can reach it easily, CAREFULLY put your hand over the area when it's running to see if you can feel the leak. (disclaimer. No responsibility taken if you burn ya hand!) Thanks, I'll give it a cautious go! Quote Link to comment Share on other sites More sharing options...
MFX Posted 10January, 2022 Report Share Posted 10January, 2022 2 hours ago, LeeM said: If you can reach it easily, CAREFULLY put your hand over the area when it's running to see if you can feel the leak. (disclaimer. No responsibility taken if you burn ya hand!) You can also use a sort piece of garden hose to your ear. It is surprisingly effective LeeM and TheBaywatchKid 2 Quote Link to comment Share on other sites More sharing options...
Mike D'Silva Posted 10January, 2022 Report Share Posted 10January, 2022 I reckon you've blown out a couple of the exhaust port plugs that are used to fill the holes, when the air injection system is removed. tomo and TheBaywatchKid 1 1 Quote Link to comment Share on other sites More sharing options...
TheBaywatchKid Posted 10January, 2022 Author Report Share Posted 10January, 2022 6 minutes ago, Mike D'Silva said: I reckon you've blown out a couple of the exhaust port plugs that are used to fill the holes, when the air injection system is removed. Thanks Mike! Mine is an 82, so I think it should have the 02 sensor rather than the air injection, but Im probably wrong! Quote Link to comment Share on other sites More sharing options...
Mike D'Silva Posted 12January, 2022 Report Share Posted 12January, 2022 On 10/01/2022 at 19:46, TheBaywatchKid said: Thanks Mike! Mine is an 82, so I think it should have the 02 sensor rather than the air injection, but Im probably wrong! any updates? Quote Link to comment Share on other sites More sharing options...
TheBaywatchKid Posted 12January, 2022 Author Report Share Posted 12January, 2022 Hi @Mike D'Silva, thanks for following up! So i sent the video to Autohaus, and they did seem to think exhaust leak as well. But the soonest they can take it is feb 3rd 😅 They also said not to drive it, and send it to them on a truck. So I'll give it a little inspection myself at the weekend, but if you have any other advice I'd love to hear it. You're a wizard on aircooled! Quote Link to comment Share on other sites More sharing options...
TheBaywatchKid Posted 18January, 2022 Author Report Share Posted 18January, 2022 I can update this now - You were close @Mike D'Silva , it was a bung from the air injection that had popped out! tomo and Dalai 2 Quote Link to comment Share on other sites More sharing options...
Mike D'Silva Posted 19January, 2022 Report Share Posted 19January, 2022 1 hour ago, TheBaywatchKid said: I can update this now - You were close @Mike D'Silva , it was a bung from the air injection that had popped out! Um, I don't think I could have been any closer. Glad you got it sorted. micknine01, tomo, GTP911 and 2 others 1 4 Quote Link to comment Share on other sites More sharing options...
TheBaywatchKid Posted 19January, 2022 Author Report Share Posted 19January, 2022 1 hour ago, Mike D'Silva said: Um, I don't think I could have been any closer. Glad you got it sorted. You were on the money. Thanks again! Quote Link to comment Share on other sites More sharing options...
TwoHeadsTas Posted 19January, 2022 Report Share Posted 19January, 2022 16 minutes ago, TheBaywatchKid said: You were on the money. Thanks again! Mike is da Man!!!!! TheBaywatchKid and WOKA 2 Quote Link to comment Share on other sites More sharing options...
