ByronBayChris Posted 22May, 2014 Report Share Posted 22May, 2014 Of course, I hear the throngs chanting, it's a 911!!!!! I have not.driven it for 4 weeks and took the cover off today to take it out. Saw this Maybe a leaking seal in the reservoir.since the oil had time to settle? Thoughts and action plan? Is it ok to drive to a hoist? (btw my background is IT - the usual disclaimer) Link to comment Share on other sites More sharing options...
Chris-p Posted 22May, 2014 Report Share Posted 22May, 2014 Chris, have you had it looked at since you drove it to Byron after the rebuild? In so far as a general tighten up of bolts etc and oil change? Link to comment Share on other sites More sharing options...
ByronBayChris Posted 22May, 2014 Author Report Share Posted 22May, 2014 No Chris, not yet It was due to go in July, but worth looking at now I guess. Thx Link to comment Share on other sites More sharing options...
Harvs11 Posted 22May, 2014 Report Share Posted 22May, 2014 That looks like only about half a cup of oil. You've got plenty left. Link to comment Share on other sites More sharing options...
ByronBayChris Posted 22May, 2014 Author Report Share Posted 22May, 2014 Thx harvs, that's what I like to hear Link to comment Share on other sites More sharing options...
FlatSix Posted 22May, 2014 Report Share Posted 22May, 2014 Did your right rear tyre get a coating of oil? Link to comment Share on other sites More sharing options...
ByronBayChris Posted 22May, 2014 Author Report Share Posted 22May, 2014 Did your right rear tyre get a coating of oil? A little. I placed a towel over the puddle to drive out so as to not get foot prints through the garage Link to comment Share on other sites More sharing options...
Peter M Posted 22May, 2014 Report Share Posted 22May, 2014 Right side of engine, Red fluid, To the rear of the rear wheel. Mmmmmmmm, I'd check the level in the power steering reservoir as my first port of call, just in case one of the hose clamps weren't tighten up after your recent head job work. Next, would be to check to see if the plastic fluid level sight gauge on your transmission is leaking/broken. Link to comment Share on other sites More sharing options...
911oclock Posted 22May, 2014 Report Share Posted 22May, 2014 Did you scare it??? Link to comment Share on other sites More sharing options...
ByronBayChris Posted 22May, 2014 Author Report Share Posted 22May, 2014 Right side of engine, Red fluid, To the rear of the rear wheel. Mmmmmmmm, I'd check the level in the power steering reservoir as my first port of call, just in case one of the hose clamps weren't tighten up after your recent head job work. Next, would be to check to see if the plastic fluid level sight gauge on your transmission is leaking/broken. It was in front of rear right wheel...I moved the car to check Link to comment Share on other sites More sharing options...
9er Posted 22May, 2014 Report Share Posted 22May, 2014 Looks red to my old eyes. Link to comment Share on other sites More sharing options...
Deejay Posted 22May, 2014 Report Share Posted 22May, 2014 Is it red ? Or is it the shiny reflection from the reflective centre strip or lights on the car. Either way, doesn't look like a great deal. Link to comment Share on other sites More sharing options...
ByronBayChris Posted 22May, 2014 Author Report Share Posted 22May, 2014 Looks red to my old eyes. Yes, red to me too. Will check the two items in the morning. Thanks guys - always know I will get a lead from somewhere Link to comment Share on other sites More sharing options...
ByronBayChris Posted 22May, 2014 Author Report Share Posted 22May, 2014 Right side of engine, Red fluid, To the rear of the rear wheel. Mmmmmmmm, I'd check the level in the power steering reservoir as my first port of call, just in case one of the hose clamps weren't tighten up after your recent head job work. Next, would be to check to see if the plastic fluid level sight gauge on your transmission is leaking/broken. Hey - language - not just head job work but also a bottom lower job too ! Link to comment Share on other sites More sharing options...
ByronBayChris Posted 22May, 2014 Author Report Share Posted 22May, 2014 Did you scare it??? My 18month old boy started to take the car cover off - that would be enough to cause this leakage Link to comment Share on other sites More sharing options...
OZ930 Posted 22May, 2014 Report Share Posted 22May, 2014 Could have gotten a bit excited about the thought of a run…….my dog does. Anyway, here is a website with some schematics which may help, http://www.autoatlanta.com/porsche-parts/964-89-94/porsche_911_parts.php Link to comment Share on other sites More sharing options...
ByronBayChris Posted 22May, 2014 Author Report Share Posted 22May, 2014 And remember that I sprung a leak at under the front which was quite watery just a few drives ago also. Maybe linked with power steering ? Thanks OZ for the exploded diagrams Link to comment Share on other sites More sharing options...
OZ930 Posted 22May, 2014 Report Share Posted 22May, 2014 And remember that I sprung a leak at under the front which was quite watery just a few drives ago also. Maybe linked with power steering ? Thanks OZ for the exploded diagrams Too much ? Link to comment Share on other sites More sharing options...
Russ Posted 23May, 2014 Report Share Posted 23May, 2014 Power steering/ATF is red usually. The watery stuff will be run off from your evaporator in the AC system smell the oil and compare it to the smell of engine oil Link to comment Share on other sites More sharing options...
Uncle Posted 23May, 2014 Report Share Posted 23May, 2014 ATF has a nasty burnt Garlic type taste. Engine oil is far more metalic tasting. Gearbox and diff oil have one of the worst tastes known to man. Agreed it looks Red to me so I'd look at the P/S. Link to comment Share on other sites More sharing options...
ByronBayChris Posted 25May, 2014 Author Report Share Posted 25May, 2014 Appears to be power steering fluid. Level is just at the bottom of the two lines. But, the burning oil smell he's disappeared..... Which is a good thing Link to comment Share on other sites More sharing options...
