SteamWolf Posted 29June, 2014 Report Share Posted 29June, 2014 ... suck the awesome out of engines. Discuss Link to comment Share on other sites More sharing options...
Uncle Posted 30June, 2014 Report Share Posted 30June, 2014 Unless they are made by say.. KKK and then they feed awesome back into the engine. Link to comment Share on other sites More sharing options...
JustJames Posted 30June, 2014 Report Share Posted 30June, 2014 Let's not forget that the infernal combustion engine is itself an air pump.So, SW, does this mean that you've bought a milk float? Link to comment Share on other sites More sharing options...
SteamWolf Posted 30June, 2014 Author Report Share Posted 30June, 2014 Hahaha this came from a discussion on saturday night where certain parties suggested the SC smog pump was an important component. Link to comment Share on other sites More sharing options...
FlatSix Posted 30June, 2014 Report Share Posted 30June, 2014 Link to comment Share on other sites More sharing options...
Tit Posted 30June, 2014 Report Share Posted 30June, 2014 I'd leave the ones Uncle is talking about on there... Link to comment Share on other sites More sharing options...
Dreamr Posted 30June, 2014 Report Share Posted 30June, 2014 I'm watching you FlatSix..... I'm here, there and everywhere..... By the way, how's YOUR smog pump treating you?? Link to comment Share on other sites More sharing options...
SteveF Posted 30June, 2014 Report Share Posted 30June, 2014 I'm watching you FlatSix..... I'm here, there and everywhere..... By the way, how's YOUR smog pump treating you?? I don't think he has one which is why his goes a bit faster than yours (that and the turbo!) Link to comment Share on other sites More sharing options...
Tit Posted 30June, 2014 Report Share Posted 30June, 2014 If your 964 came with a smog pump then you may have been duped... Link to comment Share on other sites More sharing options...
clutch-monkey Posted 30June, 2014 Report Share Posted 30June, 2014 .. what the hell is an airpump (the non-turbo variety) Link to comment Share on other sites More sharing options...
Dreamr Posted 30June, 2014 Report Share Posted 30June, 2014 The air pump they are referring to is the smog pump on the older 911's that were installed to bring down the emissions for the strict USA market. It pumps extra air directly into the exhaust to thin out the exhaust gases so they complied. They aren't required here in Oz and I've been copping a bit of flack from some of the members because I don't want to remove mine. Why? they ask.... Because it came from the factory like that and I'm happy to leave it original, I say.... But it will increase the HP of your engine, they say..... It already goes fast enough and I don't need to go 10 klms faster as I am already going to lose my licence, I say..... Smog pump lover, they say..... Link to comment Share on other sites More sharing options...
Tit Posted 30June, 2014 Report Share Posted 30June, 2014 You can put the belt back on for the concours assessor... Link to comment Share on other sites More sharing options...
clutch-monkey Posted 30June, 2014 Report Share Posted 30June, 2014 sounds like the factory would be happy for you to throw it in the bin, as they only put it on to appease the yanks.. Link to comment Share on other sites More sharing options...
Dreamr Posted 30June, 2014 Report Share Posted 30June, 2014 I wish it was just as easy as removing the belt (which I have already done but put back on..) It seems to affect the idle when the belt is off.. I believe that when you remove the pump the air hoses also have to be removed and a hole plugged up that goes to the exhaust..... Thanks everyone for the concern about my smog pump, but I've got it all under control..... Link to comment Share on other sites More sharing options...
Tit Posted 30June, 2014 Report Share Posted 30June, 2014 What about your air con compressor? Do you need that? We could help remove that too if you like? Any one have a plasma cutter? Link to comment Share on other sites More sharing options...
Dreamr Posted 30June, 2014 Report Share Posted 30June, 2014 Tit..... While I'm happy for you to admire my car, I MUST INSIST that it is from a distance.... Oh yeah, you're in Canberra..... still don't think it's far enough away...... Link to comment Share on other sites More sharing options...
tazzieman Posted 30June, 2014 Report Share Posted 30June, 2014 I wish it was just as easy as removing the belt (which I have already done but put back on..) It seems to affect the idle when the belt is off.. I believe that when you remove the pump the air hoses also have to be removed and a hole plugged up that goes to the exhaust..... Thanks everyone for the concern about my smog pump, but I've got it all under control..... The doctor is IN My view - it's an ugly piece of kit , please remove it and all the other bits of plumbing (electric blower , "air con") It's like clearing an attic of junk. Sometimes people need help in making these decisions and implementing them. You can save the bits and pieces for the next owner or make $ selling them to concours guys. When all is removed you will find it easier (and cheaper if you are not DIY) to adjust valves. And not feel embarrassed showing off your clean engine bay I've just cleaned up my 928 too. Car is lighter thus more economical and zippier If you're concerned about emissions , do what the concours guys do. Don't drive it! PS As for the idle changing , what is the matter? Rough or fast/slow? Link to comment Share on other sites More sharing options...
FlatSix Posted 30June, 2014 Report Share Posted 30June, 2014 If your 964 came with a smog pump then you may have been duped... Mine is a 964 with a modified 930 motor though. It has an air pump, I know this because my mechanic fixed it and told me the car would run better with it working. It would run better with it removed! I had no idea an "air pump" was another name for smog pump at the time. Link to comment Share on other sites More sharing options...
Tit Posted 30June, 2014 Report Share Posted 30June, 2014 Damn Californians! Link to comment Share on other sites More sharing options...
Dreamr Posted 1July, 2014 Report Share Posted 1July, 2014 Good Morning Dr,When I remove the belt the symptoms are as follows.....Sometime it idles high, sometimes it idles low, and sometimes it fluctuates...Is it serious doc?Do I need a new motor, or can we re-engineer this one...Please help me doc... it's the smog pumps fault....(How on earth did this thread become about me and my smog pump???) Seems everyone one else is more concerned about it than me...I must agree with you though, I REALLY like the clean look of your engine bay.... I just wish I wasn't such a hoarder Link to comment Share on other sites More sharing options...
Russ Posted 1July, 2014 Report Share Posted 1July, 2014 i guess you're taking some load off the engine, so if anything you'd assume it'd idle higher from what i recall there's an injector port into the exhaust and that's it, i'm not sure how it'd affect the running though! unless it makes a huge change to back pressure, but even then it shouldn't change the intake side of things maybe see on a exhaust gas analyser what your mixtures etc are like once the belt and unit is removed? good to see this thread went somewhere lol oh, and you can always keep the bits to reverse it later Link to comment Share on other sites More sharing options...
tazzieman Posted 1July, 2014 Report Share Posted 1July, 2014 Remove the belt, pump , pipes and plug the exhaust ports (very easy). It will run fine and if not your CIS needs some TLC. Hoarding is OK. I hoard. Just don't put everything on display at once Link to comment Share on other sites More sharing options...
Dreamr Posted 1July, 2014 Report Share Posted 1July, 2014 Thanks for the info and concern guys.....I think that it will take me some time (if ever) to decide to remove anything....I get the theory and practicality of it but still........ Link to comment Share on other sites More sharing options...
tazzieman Posted 1July, 2014 Report Share Posted 1July, 2014 OK let's have a pic of your engine bay. Not sure I've seen a 911 SP in the flesh. But yours could be the closest! Link to comment Share on other sites More sharing options...
Caledonian Posted 1July, 2014 Report Share Posted 1July, 2014 Leave Dreamr alone, if he just wants keep the car as it came from the factory, and there's nothing wrong with that. Oh! might want to change the colour back to as it left the factory too:) Link to comment Share on other sites More sharing options...
