Cal Posted 27August, 2014 Report Share Posted 27August, 2014 Just extract the downloaded mod straight into your rfactor install. Then the tracks go in Gamedata\Locations. I'm trying to see if AVM have a spare server they can set up for us tonight. Link to comment Share on other sites More sharing options...
FlatSix Posted 27August, 2014 Report Share Posted 27August, 2014 Yeah Russ it has a dedicated server.. Wayne dont forget to grab the tracks that Cal posted above too. Link to comment Share on other sites More sharing options...
Cal Posted 27August, 2014 Report Share Posted 27August, 2014 If AVM can't host.... and it looks like they can't tonight, are you able to Nath? Edit: yeah they can't host tonight, but here is the response: "Yeah for sure. I will put it up tomorrow night until the weekend when i will put up the Maserati event, then it will go up on Thursday September 11th for good." Link to comment Share on other sites More sharing options...
FlatSix Posted 27August, 2014 Report Share Posted 27August, 2014 I dont think my adsl1 connection would be up to it but i can try. Cal what wheel rotation do you use for the 997's? and what steering lock? Link to comment Share on other sites More sharing options...
Cal Posted 27August, 2014 Report Share Posted 27August, 2014 The Hyper is approx 180 degrees. Slightly more, maybe 200. Basically, when the steering wheel is upside down you are nearly at full lock. I have not touched the default setup yet, but I think default is 22? Feels okay out of the box. Link to comment Share on other sites More sharing options...
Russ Posted 27August, 2014 Author Report Share Posted 27August, 2014 I might be able to host, depending on what happens in the next few hours, I'll let you guys know by 6 (with an aim for the usual 7:30 start if I can do it) Link to comment Share on other sites More sharing options...
Cal Posted 27August, 2014 Report Share Posted 27August, 2014 Ok, I'll check in here at 6.30pm. Link to comment Share on other sites More sharing options...
Steiny Posted 27August, 2014 Report Share Posted 27August, 2014 Yeah Russ it has a dedicated server.. Wayne dont forget to grab the tracks that Cal posted above too. Thanks Nathan - got them. Link to comment Share on other sites More sharing options...
Cal Posted 27August, 2014 Report Share Posted 27August, 2014 Just be careful to extract the tracks to the correct place. First time I did it, I ended up with a Locations folder in the main rfactor directory. It needs to be in Gamedata. Link to comment Share on other sites More sharing options...
FlatSix Posted 27August, 2014 Report Share Posted 27August, 2014 Well I have to say the rfactor demo did not really impress me but the 997's are great. I just need to sort out my wheel settings so it doesn't wobble like crazy when I let go. If Russ can't host I'll give it a go but no guarantees my connection is up to it. Link to comment Share on other sites More sharing options...
Cal Posted 27August, 2014 Report Share Posted 27August, 2014 See how you go, but the AVM server will be up from tomorrow. I'll PM you guys the password. They told me that will be fine, so long as you sign up on the forum if you intend to race in the series. Link to comment Share on other sites More sharing options...
FlatSix Posted 27August, 2014 Report Share Posted 27August, 2014 Thanks Cal, what wheel are you using? My G25 has a serious case of the wobbles when I let go of the wheel. Link to comment Share on other sites More sharing options...
Steiny Posted 27August, 2014 Report Share Posted 27August, 2014 Thanks Cal, what wheel are you using? My G25 has a serious case of the wobbles when I let go of the wheel. Trade it in for a joystick :ph34r: Link to comment Share on other sites More sharing options...
Cal Posted 27August, 2014 Report Share Posted 27August, 2014 Thanks Cal, what wheel are you using? My G25 has a serious case of the wobbles when I let go of the wheel. Hyper ie no FFB. Turn the strength of the feedback down? Link to comment Share on other sites More sharing options...
Steiny Posted 27August, 2014 Report Share Posted 27August, 2014 Nice Link to comment Share on other sites More sharing options...
Cal Posted 27August, 2014 Report Share Posted 27August, 2014 I've owned it for 13 years and it's as good today as the day bought it. Money well spent. Link to comment Share on other sites More sharing options...
FlatSix Posted 27August, 2014 Report Share Posted 27August, 2014 Ok I've turned to wheel rotation to 270 and it seems to have fixed the problem Link to comment Share on other sites More sharing options...
Steiny Posted 27August, 2014 Report Share Posted 27August, 2014 Here's a tip. Never let go of the wheel. Apparently that's what all the good drivers say? Link to comment Share on other sites More sharing options...
Russ Posted 27August, 2014 Author Report Share Posted 27August, 2014 okay, ive got this downloaded and I'm just installing the mod and track packs once that's done I'll install on my server and crank up teamspeak and the dedicated server. should be good to go by 7 or so Link to comment Share on other sites More sharing options...
Russ Posted 27August, 2014 Author Report Share Posted 27August, 2014 always keep 2 hands firmly on your joystick eh Wayne? Link to comment Share on other sites More sharing options...
FlatSix Posted 27August, 2014 Report Share Posted 27August, 2014 Zing! Link to comment Share on other sites More sharing options...
Cal Posted 27August, 2014 Report Share Posted 27August, 2014 What teamspeak details do you guys use? Link to comment Share on other sites More sharing options...
FlatSix Posted 27August, 2014 Report Share Posted 27August, 2014 its in Russ's first post, Put 58.173.176.74 in 'address' box (this is my public IP) and 9987 into the 'Port' box and hit connect Link to comment Share on other sites More sharing options...
FlatSix Posted 27August, 2014 Report Share Posted 27August, 2014 not up yet though, Russ is just finishing up his rfactor install. Link to comment Share on other sites More sharing options...
Cal Posted 27August, 2014 Report Share Posted 27August, 2014 Yeah we are talking on FB Link to comment Share on other sites More sharing options...
