Mike D'Silva Posted 30July, 2015 Report Share Posted 30July, 2015 Anyone know how to get the spare tyre on a 964 deflated so I can get it back in the front compartment?For all my searching, I cannot find a suction pump to suit...Here's a pic of the sort of tyre I am referencing... Link to comment Share on other sites More sharing options...
KGB Posted 30July, 2015 Report Share Posted 30July, 2015 Remove the valve from the stem. Link to comment Share on other sites More sharing options...
Mike D'Silva Posted 30July, 2015 Author Report Share Posted 30July, 2015 yeah..I removed the core from the valve, and it will only deflate so far.... it needs to have the guts sucked out of it.. Link to comment Share on other sites More sharing options...
tomo Posted 30July, 2015 Report Share Posted 30July, 2015 Anyone know how to get the spare tyre on a 964 deflated so I can get it back in the front compartment?For all my searching, I cannot find a suction pump to suit...Here's a pic of the sort of tyre I am referencing...how much bigger than the 1 in th pic,never seen 1 pumped up they are a bloody awkward thing to get in on a good day, Take the black ABS cover off it gives you just that bit you need Link to comment Share on other sites More sharing options...
twood Posted 30July, 2015 Report Share Posted 30July, 2015 Mike -I have had the same problem- a search of Rennlist came up with the suggestion of using a tie down strap with a ratchet tighten er. Remove the valve -wrap the strap around the tyre and tighten. It allows that little bit of air to be removed then reinstall the the valve to stop it from reinflating.Don't expect to get the tyre back to where it was before inflating but it was enough with a little force to re install the tyre in the front boot Link to comment Share on other sites More sharing options...
Mike D'Silva Posted 30July, 2015 Author Report Share Posted 30July, 2015 how much bigger than the 1 in th pic,never seen 1 pumped up they are a bloody awkward thing to get in on a good day, Take the black ABS cover off it gives you just that bit you needmine is about 1inch larger all around.. i tried the ratchet straps, and for the life of me, cannot bet the bugger any smaller! (yes, before you ask i did it with the valve core removed!)Anyone, got a fully-deflated one they want to sell? Link to comment Share on other sites More sharing options...
Coastr Posted 30July, 2015 Report Share Posted 30July, 2015 My AC vacuum pump might do the trick? I think the smaller r134 valves are the same size as a tyre valve? I'm getting it out to vacuum check the ac, I'll see if the fitting will go on a tyre valve. Link to comment Share on other sites More sharing options...
tomo Posted 30July, 2015 Report Share Posted 30July, 2015 mine is about 1inch larger all around.. i tried the ratchet straps, and for the life of me, cannot bet the bugger any smaller! (yes, before you ask i did it with the valve core removed!)Anyone, got a fully-deflated one they want to sell?You should be able to flog off the rim to an early Speedster owner, I read (i think) they are popular. Yes if that thing is an inch bigger it ain't going back in there Link to comment Share on other sites More sharing options...
twood Posted 30July, 2015 Report Share Posted 30July, 2015 mine is about 1inch larger all around.. i tried the ratchet straps, and for the life of me, cannot bet the bugger any smaller! (yes, before you ask i did it with the valve core removed!)Anyone, got a fully-deflated one they want to sell?I have one but you have to buy the car to get it. Bring it around home night and we can see what we can do-it will be a challenge and we can check it against mine Link to comment Share on other sites More sharing options...
KGB Posted 30July, 2015 Report Share Posted 30July, 2015 After reading this mine has officially become an in situ static show piece never to be inflated in an emergency. Thank you for the heads up! Link to comment Share on other sites More sharing options...
Harvs11 Posted 30July, 2015 Report Share Posted 30July, 2015 I'd be surprised if my space saver would hold pressure. it's 30+ years old and crusty. It's a garage ornament these days. Link to comment Share on other sites More sharing options...
Coastr Posted 30July, 2015 Report Share Posted 30July, 2015 I checked the R134 fittings against the tyre valve. No, they're not even close. So vac pump would be of little use. Link to comment Share on other sites More sharing options...
Peter M Posted 30July, 2015 Report Share Posted 30July, 2015 I'd be surprised if my space saver would hold pressure. it's 30+ years old and crusty. It's a garage ornament these days. While I'm confident mine are OK and have tested one just to see, I bought one of these tyre plug repair kits thinking I may as well fix the proper tyre then and there and put it back on:http://www.supercheapauto.com.au/online-store/products/Slime-Tyre-Repair-Plug-Reamer-Kit-11-Piece.aspx?pid=342772#RecommendationsI've done one repair on my kids car and it made me wonder while I didn't buy a kit years ago. Link to comment Share on other sites More sharing options...
StevepGT3 Posted 30July, 2015 Report Share Posted 30July, 2015 While I'm confident mine are OK and have tested one just to see, I bought one of these tyre plug repair kits thinking I may as well fix the proper tyre then and there and put it back on:http://www.supercheapauto.com.au/online-store/products/Slime-Tyre-Repair-Plug-Reamer-Kit-11-Piece.aspx?pid=342772#RecommendationsI've done one repair on my kids car and it made me wonder while I didn't buy a kit years ago.Ever since I have had the porsche with only the crappy spacesaver I have carried one of those kits with me plus two cans of tyreweld,(years of riding bikes long distances) . The thought of driving back from the snowies or the like on a space saver sends shivers down my spine.Haven`t yet needed it for the car but it saved the ruination of a good long biking weekend on at least two occasions. Link to comment Share on other sites More sharing options...
Rob Posted 31July, 2015 Report Share Posted 31July, 2015 Ever since I have had the porsche with only the crappy spacesaver I have carried one of those kits with me plus two cans of tyreweld,(years of riding bikes long distances) . The thought of driving back from the snowies or the like on a space saver sends shivers down my spine.Haven`t yet needed it for the car but it saved the ruination of a good long biking weekend on at least two occasions.Steve, Not wanting to hijack the thread, but I'm interested to know re bikes how effective the tyreweld solution is - does it have sufficient pressure to re-inflate the tyre, or do you need a pump as well? Link to comment Share on other sites More sharing options...
StevepGT3 Posted 31July, 2015 Report Share Posted 31July, 2015 Steve, Not wanting to hijack the thread, but I'm interested to know re bikes how effective the tyreweld solution is - does it have sufficient pressure to re-inflate the tyre, or do you need a pump as well?Bike adventures were pre the existence of tyreweld so always carried a pump, however having used it a few times on car tyres, 235x45x17, giving about 20lb I think it should easily do a bike tyre, unless of course it is only capable of volume not pressure, so not sure Link to comment Share on other sites More sharing options...
Russ Posted 31July, 2015 Report Share Posted 31July, 2015 i've used a 'tyre weld' equivilent and had to pump it up a bit using the portable air compressor too Link to comment Share on other sites More sharing options...
